70 Charger headlight relay #460714
09/06/09 01:00 PM
09/06/09 01:00 PM
South San Francisco, Ca
70sixpkrt Offline OP
Where does the headlight relay bolt up to under the dash on a 70 Charger? I know it is some where near the steering column.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 70 Charger headlight relay [Re: 70sixpkrt] #460715
09/06/09 01:12 PM
09/06/09 01:12 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
It attaches to the inside bottom of the dash frame on the LH side. I believe it is the farthest outside attachment hole. The screw goes through bottom of dash frame and into relay bracket. For refernce, it will be mounted nearly directly under the headlight switch.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 Charger headlight relay [Re: 70gtx440dana] #460716
09/06/09 01:14 PM
09/06/09 01:14 PM
Thanks for the info. Any pics?
4-speed
3:54 Dana
Re: 70 Charger headlight relay [Re: 70sixpkrt] #460717
09/06/09 01:27 PM
09/06/09 01:27 PM
Lansing, MI
Lansing, MI
I do not have any pictures mounted. Here is one of the relay. Your dash frame will already have the attachment hole in it. The electrical connector faces the upward when mounted.
Re: 70 Charger headlight relay [Re: 70gtx440dana] #460718
09/06/09 01:57 PM
09/06/09 01:57 PM
So the hole faces down into the dash lip and the wires face upward. Thanks!!
4-speed
3:54 Dana
Re: 70 Charger headlight relay [Re: 70sixpkrt] #460719
09/06/09 02:33 PM
09/06/09 02:33 PM
Lansing, MI
Lansing, MI
Yes - The connector hangs/cantilevers towards firewall, not toward front of dash.
Re: 70 Charger headlight relay [Re: 70gtx440dana] #460720
09/06/09 04:01 PM
09/06/09 04:01 PM
Thanks. I just bolted it up from the dash lip. Does anybody rebuild the headlight door motors?
4-speed
3:54 Dana
Re: 70 Charger headlight relay [Re: 70sixpkrt] #460721
09/06/09 07:56 PM
09/06/09 07:56 PM
Lansing, MI
Lansing, MI
Yes - There are a couple guys rebuilding them. I believe at least one is a member here. Put out a new question looking for this service and you should get some replys.
Re: 70 Charger headlight relay [Re: 70gtx440dana] #460722
09/06/09 07:59 PM
09/06/09 07:59 PM
Lansing, MI
Lansing, MI
I just did a quick search and found one of the guys re-building head light motors. His website info is pasted below.
Some of you know that I rebuild/restore the headlight motors for 66 & 67 Chargers. What you may not know is that I am expanding my services to include wiper, window, and 70^ headlight motors. My website is www.headlightmotorman.web.officelive.com Check it out and let me know what you think.
Re: 70 Charger headlight relay [Re: 70gtx440dana] #460723
09/06/09 08:57 PM
09/06/09 08:57 PM
Thanks. I found that website earlier on www.dodgecharger.com board
4-speed
3:54 Dana
