Re: 70 Charger headlight relay
[Re: 70sixpkrt]
#460715
09/06/09 01:12 PM
09/06/09 01:12 PM
Posts: 3,528 Lansing, MI
70gtx440dana
Lansing, MI
It attaches to the inside bottom of the dash frame on the LH side. I believe it is the farthest outside attachment hole. The screw goes through bottom of dash frame and into relay bracket. For refernce, it will be mounted nearly directly under the headlight switch.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70sixpkrt]
#460717
09/06/09 01:27 PM
09/06/09 01:27 PM
70gtx440dana
Lansing, MI
I do not have any pictures mounted. Here is one of the relay. Your dash frame will already have the attachment hole in it. The electrical connector faces the upward when mounted.
[Re: 70sixpkrt]
#460719
09/06/09 02:33 PM
09/06/09 02:33 PM
70gtx440dana
Lansing, MI
Yes - The connector hangs/cantilevers towards firewall, not toward front of dash.
[Re: 70sixpkrt]
#460721
09/06/09 07:56 PM
09/06/09 07:56 PM
70gtx440dana
Lansing, MI
Yes - There are a couple guys rebuilding them. I believe at least one is a member here. Put out a new question looking for this service and you should get some replys.
[Re: 70gtx440dana]
#460722
09/06/09 07:59 PM
09/06/09 07:59 PM
70gtx440dana
Lansing, MI
I just did a quick search and found one of the guys re-building head light motors. His website info is pasted below. Some of you know that I rebuild/restore the headlight motors for 66 & 67 Chargers. What you may not know is that I am expanding my services to include wiper, window, and 70^ headlight motors. My website is www.headlightmotorman.web.officelive.com Check it out and let me know what you think.
