Re: Ignition Timing Test - Track results
[Re: 440Jim]
#460608
09/06/09 11:54 AM
09/06/09 11:54 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
It's interesting it didn't change ET's more I didn't make back to back changes on mine but picked up a bunch from moving the timing from 32 to 35. I'd have to dig through the log book but I think it was on the order of .05 in the 1/8.
[Re: 440Jim]
#460609
09/06/09 12:20 PM
09/06/09 12:20 PM
Posts: 903 Saskatchewan, Canada
cudabin
Great post Jim Based on your results, i assume you will run 32 degrees in the future? What affect do you think the lower DA you run at has on the timing needed? We typically run around 4,000 feet DA so I was thinking my combo may want 33 - 34 degrees, but like you did, i will need to test... Thanks for the real world info! Cheers, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: Cab_Burge]
#460611
09/06/09 01:01 PM
09/06/09 01:01 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Nice post Jim... looks like the Indy combustion chamber is pretty efficient compared to stock 40 year old stuff. i never understood why guys wanted to run 38-40 deg of timing, never check to see if it needs that much. IMO running the least amount of timing without effect performance really helps the life span of a engine, big inch engines on two steps, running 10 more degree's of timing than needed, and they wonder why it needs bearings every year. I would love to see a test like this regarding plug gap. More so with Methanol. I have preached a few times to some fellow buddy's about watching plug gap on alky. I have found it very sensitive, in my case... A
Great info, should be in the tech archive's.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Cab_Burge]
#460612
09/06/09 01:03 PM
09/06/09 01:03 PM
Posts: 16,931 NC
440Jim
NC
I can only think a few things:
- This combo isn't real sensitive to ignition timing (in this range) - The flying toilet injection is pretty consistant - The E-85 fuel is pretty consistant
I do try to keep all the variables as consistant as I can, both for this testing comparison and during bracket racing. Water temp, engine oil temp, trans fluid temp, staging rpm (foot and eye), burn out technique, etc. All those 5 runs were at similar weather conditions, 86 degree, 30% RH, 30.07"Hg. It didn't start cooling off with relative humidity going up until the eliminations in the evening (9pm 1st round)
[Re: 440Jim]
#460613
09/08/09 08:31 PM
09/08/09 08:31 PM
cudabin
I talked to Mike at Muscle Motors today and he suggessted 30 - 32 degrees for my new 540 bullet on Alky. He said the high compression needs less timing in general w/ 440-1 heads... He must be reading Jim's posts ! Arnie
