69 RR with Performer RPM intake?
#460530
09/06/09 08:50 AM
09/06/09 08:50 AM
Posts: 79 North NJ
a6t9vette
North NJ
Anyone running a Performer RPM 383 intake, on a 69 Road Runner with stock hood? Im trying to find info on hood clearance, and what type of air cleaner your running? Im hoping to keep my stock air cleaner, but may have to use a drop down base....
69 Road Runner, numbers matching 383, Auto.
Re: 69 RR with Performer RPM intake?
[Re: a6t9vette]
#460532
09/07/09 09:40 AM
09/07/09 09:40 AM
Posts: 75,061 U.S.S.A.
JohnRR
U.S.S.A.
Is your car air grabber equipped ? If not there is a ford motorsport open element air cleaner that uses the same diameter element as the stock unsilenced air cleaner , it is made for a holley though so if you are running a carter you'll need to modify the fuel line .
As far as uing the 440 air grabber unit , the 440 unit is only 3/4 inch , I think maybe less, shorter than the 383 unit , the RPM I'm sure is TALLER than what the air cleaner is shorter by so even that one I doubt would work .
[Re: gtx6970]
#460535
09/07/09 05:02 PM
09/07/09 05:02 PM
Posts: 2,295 dark side of the moon
Dougsmopars
i have the performer RPM on my 440 with stock unsilanced air cleaner. No issue with clearence. Stock 68 GTX hood.
[Re: Dougsmopars]
#460536
09/07/09 09:18 PM
09/07/09 09:18 PM
JohnRR
U.S.S.A.
That's interesting , I wouldn't have expected that especially after reading the link above .
[Re: JohnRR]
#460538
09/08/09 10:18 AM
09/08/09 10:18 AM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
Hey John do you have a part number or link to the motorsport open element air cleaner that you are mentioning?
