Why is this engine back firing out the carb? MSD? #459909
09/05/09 10:46 AM
09/05/09 10:46 AM
IN
Dartman928 Offline OP
IN
Guys would like some opinions on this. Last year the car aquired a nast kick back when you go to start it. I have a msd digital 6 box. The has been set-up the same for 3-4 years and then this problem starts to happen. I have 10:1 pump gas engine. I just keep thinking it has to be the msd is retarding the timing too much on the start. I have tried the dial on the box with 20 degrees out and turn it off and it doesn't matter. Just wondering if anyone else has come across this. Most people know that once the car gets together I don't change anything maybe other than the plug LOL.
Its just kinda strange that this problem just started out of the blue and I promis I did not change anything LOL.
I really don't want to buy another msd digital 6 as a test mule. I would like to get the car to the classic so I can race for the 1st time in 2 years
Thank you
Re: Why is this engine back firing out the carb? MSD? [Re: Dartman928] #459910
09/05/09 10:53 AM
09/05/09 10:53 AM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Turn the retard off, you dont need it.
Re: Why is this engine back firing out the carb? MSD? [Re: cudabunch] #459911
09/05/09 10:56 AM
09/05/09 10:56 AM
IN
IN
I have turned the retard off. I keep thinking that its like the retard is on all time even if I have it turned off.
Re: Why is this engine back firing out the carb? MSD? [Re: Dartman928] #459912
09/05/09 11:10 AM
09/05/09 11:10 AM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Is the distributor locked out ?
Re: Why is this engine back firing out the carb? MSD? [Re: cudabunch] #459913
09/05/09 11:11 AM
09/05/09 11:11 AM
Q
Quicktree Offline
Quicktree  Offline
Q
you need more fuel, try a bigger squirter
Re: Why is this engine back firing out the carb? MSD? [Re: Quicktree] #459914
09/05/09 11:13 AM
09/05/09 11:13 AM
Q
Quicktree Offline
Quicktree  Offline
Q
here's an easy test pump the gas 2 full times and see if it does it.
Re: Why is this engine back firing out the carb? MSD? [Re: Quicktree] #459915
09/05/09 11:23 AM
09/05/09 11:23 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
you probably need to phase the rotor if you locked out the timing
http://www.msdignition.com/instructions/...RIBUTOR+pHASING
the rotor
http://www.summitracing.com/parts/MSD-84211/
somewher it says locked out may need phasing to use 20 deg retard
http://www.msdignition.com/instructions/Products/Distributors/84211.pdf?terms=84211
Re: Why is this engine back firing out the carb? MSD? [Re: cudabunch] #459916
09/05/09 11:44 AM
09/05/09 11:44 AM
IN
IN
Yes the distributor has been locked out for 6 years. This problem has just started to occur in the last 2 years.
I have tried eveything with the carb starting proccess. One pump..blades 1/4 open to half a pump blades half open etc. I run a pro-systems 1250cfm.
Re: Why is this engine back firing out the carb? MSD? [Re: Dodgem] #459917
09/05/09 11:47 AM
09/05/09 11:47 AM
SWEET HOME ALABAMA
I
ITSDUSTA416 Offline
ITSDUSTA416  Offline
I
SWEET HOME ALABAMA
Borrow a 6AL and see if that fixes the problem.
71 DUSTER 416 ET 6.33 @ 107 1.33 60FT
Re: Why is this engine back firing out the carb? MSD? [Re: ITSDUSTA416] #459918
09/05/09 11:50 AM
09/05/09 11:50 AM
IN
IN
Don't have any friends with a 6 al...
Has anyone else had this problem?
Re: Why is this engine back firing out the carb? MSD? [Re: Quicktree] #459919
09/05/09 12:30 PM
09/05/09 12:30 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Have to agree.. the current motor in my car does it now and you pump it and it turns over smooth.. My solution however is that this engine is coming out, so...
Re: Why is this engine back firing out the carb? MSD? [Re: RemCharger] #459920
09/05/09 12:36 PM
09/05/09 12:36 PM
IN
IN
So is this a lean start condition?
Re: Why is this engine back firing out the carb? MSD? [Re: Dartman928] #459921
09/05/09 12:41 PM
09/05/09 12:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
ummmm yes, did you read my post it is a possibility.
