Why is this engine back firing out the carb? MSD?
#459909
09/05/09 10:46 AM
09/05/09 10:46 AM
Posts: 2,792 IN
Dartman928
IN
Guys would like some opinions on this. Last year the car aquired a nast kick back when you go to start it. I have a msd digital 6 box. The has been set-up the same for 3-4 years and then this problem starts to happen. I have 10:1 pump gas engine. I just keep thinking it has to be the msd is retarding the timing too much on the start. I have tried the dial on the box with 20 degrees out and turn it off and it doesn't matter. Just wondering if anyone else has come across this. Most people know that once the car gets together I don't change anything maybe other than the plug LOL. Its just kinda strange that this problem just started out of the blue and I promis I did not change anything LOL. I really don't want to buy another msd digital 6 as a test mule. I would like to get the car to the classic so I can race for the 1st time in 2 years ![](/ubbthreads/images/graemlins/biggrin.gif) Thank you ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: Why is this engine back firing out the carb? MSD?
[Re: cudabunch]
#459911
09/05/09 10:56 AM
09/05/09 10:56 AM
Posts: 2,792 IN
Dartman928
IN
Turn the retard off, you dont need it.
I have turned the retard off. I keep thinking that its like the retard is on all time even if I have it turned off.
[Re: Quicktree]
#459919
09/05/09 12:30 PM
09/05/09 12:30 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
here's an easy test pump the gas 2 full times and see if it does it.
Have to agree.. the current motor in my car does it now and you pump it and it turns over smooth.. My solution however is that this engine is coming out, so... ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: RemCharger]
#459920
09/05/09 12:36 PM
09/05/09 12:36 PM
Posts: 2,792 IN
Dartman928
IN
So is this a lean start condition? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: Dartman928]
#459921
09/05/09 12:41 PM
09/05/09 12:41 PM
Quicktree
ummmm yes, did you read my post it is a possibility.
