Bog off lthe line
#459740
09/05/09 08:16 AM
09/05/09 08:16 AM
My car has got a bog when I come off the line and then picks right back up. I tried bigger squirters,but it didn't help. It only does it when I leave on the convertor,I think the convertor is too big for the car,becuz when I shift at 6200-6300 it only drops to 5500 and on the dyno motor only made power to 5600. convertor flashes to 5000. I first noticed the bog when I put this convertor in and now the car has slowed down.2 in the 1/8. Any help or ideas???? THANKS EDDIE B P.S. It's a sixpac for now,but had about enough of that too!!!!!!!!!!!!!!
Re: Bog off lthe line
[Re: Quicktree]
#459742
09/05/09 09:38 AM
09/05/09 09:38 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
add a 50cc pump to the center carb. you have vacuum secondaries, right?
6.5 pv regardless of the vac it makes 50 cc pump and 35 sqirter on center carb
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
#459743
09/05/09 11:52 AM
09/05/09 11:52 AM
Posts: 43,292 Bend,OR USA
Cab_Burge
Shift it higher, most six paks make peak power at or below 5600 RPM, your converter uis going back to the flash stall, try 6400 or so and see if that helps, unless it really struggles to get to 6400 or so I have had three different six pak motors on a engine dyno, all of them made peak power below 5800rpm and all of them run faster in the car shiftinf=g at or above 6400 rpm
