Page 7 of 19 1 2 5 6 7 8 9 18 19
Re: BARRELCUDA: Weekends over BACK 2 WORK [Re: Mastershake340] #45950
10/10/07 07:57 PM
10/10/07 07:57 PM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
I'd be happy to trade you a correct for '71-up parkerized type finish disc brake master cylinder for that correct for '70 only '171 you got on there now....
This car had a 171 on it when i got it. Can you absolutly prove that they are a 1970 thing only? My car was built Nov. 70 if that matters....
CHECK OUT MY NEW WEB SITE !
Re: BARRELCUDA: Weekends over BACK 2 WORK [Re: anlauto] #45951
10/10/07 08:33 PM
10/10/07 08:33 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
In '71 they went with a sort of "one size fits all" disc brake master cylinder p/n 3461176 (B, C,E, and some light trucks). A bodies used an almost identical master cylinder (casting number and bore diameter same). The only exception I know of is the p/n 2944476 which was carried over from '70 for disc brake hemi cars.
The 2229171 casting number is the p/n 2944453 which is '70 e body disc brakes only. You can look on the fender side of the casting of your '9171 for a date code, the upper line will include "9175" which is some sort of assembly line or plant code, and the line below it will be the date code. "9 324" for example would be the 324th day of '69. Anyway, check that number and see if it seems at all close to late summer/early fall of '70 to get an idea of if there is any hint that one could be the original for your car. I've never seen a '171 on a '71 E body, so I doubt any were built with them.
But as they say with Mopars, anything was possible I guess!
Re: BARRELCUDA: Weekends over BACK 2 WORK [Re: Mastershake340] #45952
10/10/07 08:53 PM
10/10/07 08:53 PM
I love it.I want to do this with everything I own.My 'Cuda.My Charger.My S10! and cars I don't even own yet!
Re: BARRELCUDA: Weekends over BACK 2 WORK [Re: Mastershake340] #45953
10/10/07 09:06 PM
10/10/07 09:06 PM
anlauto Offline OP
anlauto  Offline OP
My casting is too rough or rusted to get any kind of numbers off of it.
Re: BARRELCUDA: Weekends over BACK 2 WORK [Re: anlauto] #45954
10/10/07 10:56 PM
10/10/07 10:56 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
keep 'em coming Alan. I can only hope mine comes out 1/2 as nice as yours !
Re: BARRELCUDA: Weekends over BACK 2 WORK [Re: shakerjoe] #45955
10/11/07 12:09 AM
10/11/07 12:09 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
on my 71 gtx oct 10 1970 disc brake master cylinder is casting number is 346187
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: BARRELCUDA: Weekends over BACK 2 WORK [Re: anlauto] #45956
10/11/07 12:24 AM
10/11/07 12:24 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
I'd guess the latter
Re: BARRELCUDA: Day 11 UPDATE ! [Re: anlauto] #45957
10/11/07 06:51 PM
10/11/07 06:51 PM
anlauto Offline OP
anlauto  Offline OP
Ok...So Brewers came through with the correct flywheel in record time and UPS was kind enough to only add on another $85 to the cost
But here it goes...The engine transmission were mated
Re: BARRELCUDA: Day 11 UPDATE ! [Re: anlauto] #45958
10/11/07 06:52 PM
10/11/07 06:52 PM
anlauto Offline OP
anlauto  Offline OP
...everything seems to be ok....
Re: BARRELCUDA: Day 11 UPDATE ! [Re: anlauto] #45959
10/11/07 06:53 PM
10/11/07 06:53 PM
anlauto Offline OP
anlauto  Offline OP
Here's the wind-up...a straight drive right up the center
Re: BARRELCUDA: Day 11 UPDATE ! [Re: anlauto] #45960
10/11/07 06:54 PM
10/11/07 06:54 PM
anlauto Offline OP
anlauto  Offline OP
....and PRESTO
Re: BARRELCUDA: Day 11 UPDATE ! [Re: anlauto] #45961
10/11/07 06:55 PM
10/11/07 06:55 PM
anlauto Offline OP
anlauto  Offline OP
Total time including assembling trans-motor was under 4 hours
Re: BARRELCUDA: Day 11 UPDATE ! [Re: anlauto] #45962
10/11/07 06:56 PM
10/11/07 06:56 PM
anlauto Offline OP
anlauto  Offline OP
...have wheels....lets roll...
Re: BARRELCUDA: Day 11 UPDATE ! [Re: anlauto] #45963
10/11/07 06:57 PM
10/11/07 06:57 PM
anlauto Offline OP
anlauto  Offline OP
Underside....
Re: BARRELCUDA: Day 11 UPDATE ! [Re: anlauto] #45964
10/11/07 07:34 PM
10/11/07 07:34 PM
Spring Mount, PA
MOPAULY Offline
MOPAULY  Offline
Spring Mount, PA
You are quite a barrelcuda pimp
but that looks very well done
like watching a new car get built.
Re: BARRELCUDA: Day 11 UPDATE ! [Re: anlauto] #45965
10/11/07 07:39 PM
10/11/07 07:39 PM
C.R. Iowa
supserdave Offline
supserdave  Offline
C.R. Iowa
Nice job man, those pics put a smile on my face! Can't wait to see it all together.
Re: BARRELCUDA: Day 11 UPDATE ! [Re: supserdave] #45966
10/11/07 08:13 PM
10/11/07 08:13 PM
Smithville .Ontario,Canada
fastback383 Offline
fastback383  Offline
Looking good Alan, I can't believe that is the same car. Are you going to take it up to Marrit Hall Ancaster this weekend and show it off ? Dave.
Re: BARRELCUDA: Day 11 UPDATE ! [Re: MOPAULY] #45967
10/11/07 08:21 PM
10/11/07 08:21 PM
looking good Alan...which door is getting the empty beer bottle tossed in?
Re: BARRELCUDA: Day 11 UPDATE ! [Re: fastback383] #45968
10/11/07 08:22 PM
10/11/07 08:22 PM
Wow---i really cannot believe how awesome of a job you are doing! Its just amazing, simply amazing Allan! Would you like to do my Charger for me!?
Re: BARRELCUDA: Day 11 UPDATE ! #45969
10/11/07 08:57 PM
10/11/07 08:57 PM
Alan, why didn't you paint the bellhousing?
