Best Source For A Drop Base Air Cleaner - Small Block #459364
09/04/09 09:51 PM
09/04/09 09:51 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Friend needs a bit of hood clearance on his 340 Demon (Holley 950 on a single plane intake, W2 heads) and is hunting for a drop base A/C unit, can anyone reccomend a source?
Re: Best Source For A Drop Base Air Cleaner - Small Block [Re: ScottSmith_Harms] #459365
09/04/09 10:00 PM
09/04/09 10:00 PM
IN
ahy Offline
ahy  Offline
IN
Your local autoparts store may hook him up. I got a drop base Edelbrock filter at Autozone; about $20. If that doesn't work Summit has about a 1000 different types with various drops.
In my application, the Edelbrock gave about as much drop as I could use without significant changes to the throttle and return spring linkage.
Re: Best Source For A Drop Base Air Cleaner - Small Block [Re: ahy] #459366
09/04/09 10:30 PM
09/04/09 10:30 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Moroso has a decent air cleaner selection.
Re: Best Source For A Drop Base Air Cleaner - Small Block [Re: ScottSmith_Harms] #459367
09/04/09 10:47 PM
09/04/09 10:47 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
I use a Moroso but be sure to check that the carb/throttle pressure linkage doesn't hit the base and get stuck with some of the really low drop bases.
Re: Best Source For A Drop Base Air Cleaner - Small Block [Re: ScottSmith_Harms] #459368
09/05/09 12:29 AM
09/05/09 12:29 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
There are plenty of drop bases available, most are based on a 14" air filter... I wanted to keep the stock Mopar 13" unsilenced air cleaner top so I used the bottom half of one of these Ford Air cleaners...Only a 5/8" drop but it does what I needed...
http://cgi.ebay.com/ebaymotors/1965-1995...d=p4506.c0.m245
Re: Best Source For A Drop Base Air Cleaner - Small Block [Re: ScottSmith_Harms] #459369
09/05/09 01:56 AM
09/05/09 01:56 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
I have found a KILLER drop base air cleaner setup at the local circle track shop - all spun aluminum with a great curve to both the top and bottom pieces which look like it would really improve air flow. And the BEST part - very inexpensive! like $35. I have one sitting over at the ProMax shop for this weekends open house. If it goes over well I may try and talk them into stocking them. I will try a get a couple of pics to upload in a day or too (too busy enjoying the US Nationals to do it asap)
Or better yet - call ProMax and ask them to send a pic!
tell'em Scotty told you to call!
Re: Best Source For A Drop Base Air Cleaner - Small Block [Re: ScottSmith_Harms] #459370
09/05/09 06:56 AM
09/05/09 06:56 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Like mentioned above - I used a circle track air cleaner base. IIRC, about a 2" drop, 16" diameter, a little tweeking on my stock linkage.
Re: Best Source For A Drop Base Air Cleaner - Small Block [Re: BSB67] #459371
09/05/09 10:43 AM
09/05/09 10:43 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
nice products but not cheap regular and Dominator
http://www.universalspinners.com/
Re: Best Source For A Drop Base Air Cleaner - Small Block [Re: Dodgem] #459372
09/05/09 11:00 AM
09/05/09 11:00 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Top and base - $66, plus shipping w/o element
Re: Best Source For A Drop Base Air Cleaner - Small Block [Re: BSB67] #459373
09/05/09 11:13 AM
09/05/09 11:13 AM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
I have one. 14" 2 1/4" drop base. Base only. $20 Never used, just mocked up. I thought I would need it for hood clearance, but did not.
codfish
Re: Best Source For A Drop Base Air Cleaner - Small Block [Re: ScottSmith_Harms] #459374
09/05/09 12:10 PM
09/05/09 12:10 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Well, problem has been temporarily solved. His Chevy buddy produced a rare and original chromed COPO Camero air cleaner unit that fit perfectly. The deal with the devil? He told him he has to leave the Chevy sticker on top of it!
I'll post a pic later. After I get a look at it for some measurements I'll be fabbing up a replacement ASAP! Apparently with the W2 intake, 2.00" spacer, and the Holley 950 he needed around 4.00" of drop which none of the aftermarket drop bases he could find locally had (Kelowna BC). Final outcome using the COPO unit leaves 1/4" hood clearance, good thing he has a good torque strap!
Re: Best Source For A Drop Base Air Cleaner - Small Block [Re: ScottSmith_Harms] #459375
09/05/09 01:22 PM
09/05/09 01:22 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
A 4" drop is probaly gonna make for a major air flow restriction.. How much distance between the base & the lid at the pinch point?? Not much I'll bet...
Re: Best Source For A Drop Base Air Cleaner - Small Block [Re: 1_WILD_RT] #459376
09/05/09 02:56 PM
09/05/09 02:56 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Exactly. After 2 or so inches of drop, it really does not matter. It really becomes a question of carb to hood clearance and the narrowest restriction between the carb and A/C lid. Increasing the drop will just allows a taller element.
Re: Best Source For A Drop Base Air Cleaner - Small Block [Re: BSB67] #459377
09/05/09 03:19 PM
09/05/09 03:19 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I haven't seen it so I don't know what the top of carb to lid spacing is, but I agree, thin it too much and it's going to be a dam in the river for sure.
Re: Best Source For A Drop Base Air Cleaner - Small Block [Re: ScottSmith_Harms] #459378
09/05/09 09:20 PM
09/05/09 09:20 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Alot of guys running the extreme drop bases will use the flow through lids with filter built in, the the Summit and K&N ones.
codfish
