what is this block?
#459353
09/04/09 09:26 PM
09/04/09 09:26 PM
Posts: 146 Nuevo leon,mexico,Monterrey
asesino
Hi there, i find this block and i don't knwow what kind of block is, the heads is more highers than a 400 I saw down of the left head but don't have any number and by the left side down the manifold ,only have this number 2205217 thanks
xASESINOx
Re: what is this block?
[Re: asesino]
#459358
09/04/09 09:42 PM
09/04/09 09:42 PM
340dart4spd
Parts Problem
Parts Problem
and more
just a guess..maybe a 361
[Re: asesino]
#459359
09/04/09 10:12 PM
09/04/09 10:12 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Did you transpose the numbers maybe? 2205712 is 361 from 1958-66...
[Re: dweller]
#459361
11/16/09 02:02 PM
11/16/09 02:02 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
And it appears to be a B-engine by the appearances around where the intake meetsthe heads and block. The 2-barrel suggests a B-engine also, unless the industrial RB engines used the uncommon 2-barrel intake from the 59-60 RB 383.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: dweller]
#459363
11/17/09 12:19 AM
11/17/09 12:19 AM
Posts: 862 Doo-Dah, KS
440fied
Doo-Dah, KS
It is clearly a Chrysler Industrial big block with the unique industrial head (sodium filled small valves, water pump passages into the heads, special exhaust manifolds). Looks like it has been retrofitted with a passenger car water pump housing and the head passages blocked off. The exhaust manifolds do not interchange with other heads, but the intake does. For displacement, look on the machined pad next to the passenger side head at the front of the motor...
