CAN A MACHINE SHOP CHECK THE STROKE ? #459269
09/04/09 07:26 PM
09/04/09 07:26 PM
Gateway to the West.
hemi_harvester Offline OP
Is there a way to check the stroke on a crank without the rest of the engine..
ie: I have a hemi crank I want to sell, but want to make sure of the stroke first.
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: CAN A MACHINE SHOP CHECK THE STROKE ? [Re: hemi_harvester] #459270
09/04/09 07:47 PM
09/04/09 07:47 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
if they can't time to look for a new one.
Measure the crank journals, measure the rod journals, place crank in a set of stands, measure the height of the crank journal, measure the height of the rod journal, do the math.
Or if they have a lathe or crank grinding machine, true up the crank, measure the distance from the center to the outside of the rod journal, subtract half the journal....
Re: CAN A MACHINE SHOP CHECK THE STROKE ? [Re: RodStRace] #459271
09/04/09 07:49 PM
09/04/09 07:49 PM
Thanks...
Re: CAN A MACHINE SHOP CHECK THE STROKE ? [Re: hemi_harvester] #459272
09/05/09 12:34 AM
09/05/09 12:34 AM
Cab_Burge Online work
Cab_Burge  Online Work
A good machine shop should have a cranskhaft stroke checker. I'm not a machine shop and I have two of them, one of them for checking the stroke off of the mains with the crankshaft on a set of V blocks and the other for checking the stroke on the pistons once the motor is assemble or mocked up for checking
