how do i remove door glass? #459074
09/04/09 01:47 PM
09/04/09 01:47 PM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
i`m trying to get the glass out of the door on my 47 desoto 2 door sedan. it doesn`t look like its bolted in. how does it come out?
Re: how do i remove door glass? [Re: 65rbdodge] #459075
09/04/09 02:16 PM
09/04/09 02:16 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
didn't find a glass procedure, but something in here might help
http://www.imperialclub.com/Repair/Body/index.htm
Nothing over here
http://www.oldirononline.com/
I'd say that the channel at the bottom is press fit with the rubber. You have to remove the window and channel from the crank arms.
Re: how do i remove door glass? [Re: 65rbdodge] #459076
09/07/09 09:35 PM
09/07/09 09:35 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Not sure, but the glass is probably glued to the window lift channel. On my 47 Plymouth you had to remove the guide bar and slide the channel towards the rear (or front, don't remember for sure.) Sorry, its been a few years. Gene
Re: how do i remove door glass? [Re: poorboy] #459077
09/08/09 09:24 PM
09/08/09 09:24 PM
orangeville,PA
P
plmczy Offline
plmczy  Offline
P
orangeville,PA
I pulled the glass(well what was left of it) and window mechinisms out of a 47 dodge tudor. If you want to pull just the channel with the glass out, there are two round clips that fasten the channel to the lifting arms. remove them and you should be able to pull the glass out. The glass is "glued" to the channel. You might be able to heat up the channel with a hair dryer or heat gun to soften the rubber and pull the channel off. later shawn
