Re: 727 acumulator spring??
[Re: Gearhead383]
#458842
09/04/09 09:32 AM
09/04/09 09:32 AM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
What you are doing or want out of the transmission? Is this a racecar or a daily driver? Removing the spring will allow harder shifts. I did this for a guy who had an everyday street car. At first he thought it was great. About a month later he asked me to tone it down.
I had it out of my trans with a billet accumulator piston that used double seal rings for 110k miles in my daily driver Diesel pick up , it was BRUTAL , filing rattling shifts , I dropped the VB the other day , put it back and the truck its actually a pleasure to drive.
HARD shifts do NOT actually equal GOOD shifts ...
[Re: Mr.Yuck]
#458844
09/04/09 12:45 PM
09/04/09 12:45 PM
Posts: 1,456 oklahoma
forphorty
oklahoma
I think w/ Man valve bodies it tells you to remove it.
yep, Turbo Action MVB instructions tell you to remove it. I think most of the shift kits say the same.
[Re: John_Kunkel]
#458850
09/04/09 05:37 PM
09/04/09 05:37 PM
JohnRR
U.S.S.A.
It cushions the 1 to 2 shift.
Oldest myth in the Mopar world, no matter how many times it's repeated and by whom it's still a myth.
There are only two logical reasons to remove the outer accumulator spring:
1) To install a blocker rod (blocking the piston is the ONLY accumulator mod that will firm up the 1-2 shift) 2) To shave off 2 ounces of weight
Leaving it in has the benefit of staving off a rear clutch failure.
John , does it have an effect on the 2-3 shift ? That's the one that was the hardest hitting shift in my truck , BUT the clip that holds the boost valve on top of the VB was also broken and the valve was stuck in the open position , so I'm not really sure what softened my 2-3 ??
[Re: Lew]
#458854
09/05/09 06:19 AM
09/05/09 06:19 AM
Posts: 316 Coolville, Ohio
Lew
Coolville, Ohio
some say take it out, some say leave it in, what is its job?
thanks for all the repleys, good info, think ill leave it out.
[Re: Lew]
#458855
09/05/09 09:41 AM
09/05/09 09:41 AM
Posts: 15,478 the boonies
aarcuda
the boonies
are you going to block it too? or just leave it floating?
[Re: John_Kunkel]
#458857
09/06/09 09:48 AM
09/06/09 09:48 AM
JohnRR
U.S.S.A.
Nope, after the 1-2 shift is complete the accumulator piston remains at the end of its bore in the case during the 2-3 shift and doesn't leave there until the trans downshifts to 1st.
Thanks , must have been something with that boost valve bracket being broken .
