727 acumulator spring?? #458839
09/04/09 05:36 AM
09/04/09 05:36 AM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
some say take it out, some say leave it in, what is its job?
Re: 727 acumulator spring?? [Re: Lew] #458840
09/04/09 07:39 AM
09/04/09 07:39 AM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
It cushions the 1 to 2 shift. Take it out and shim the piston up , and go chirp some tires.
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: 727 acumulator spring?? [Re: Lew] #458841
09/04/09 07:43 AM
09/04/09 07:43 AM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
What you are doing or want out of the transmission? Is this a racecar or a daily driver? Removing the spring will allow harder shifts. I did this for a guy who had an everyday street car. At first he thought it was great. About a month later he asked me to tone it down.
Re: 727 acumulator spring?? [Re: Gearhead383] #458842
09/04/09 09:32 AM
09/04/09 09:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I had it out of my trans with a billet accumulator piston that used double seal rings for 110k miles in my daily driver Diesel pick up , it was BRUTAL , filing rattling shifts , I dropped the VB the other day , put it back and the truck its actually a pleasure to drive.
HARD shifts do NOT actually equal GOOD shifts ...
Re: 727 acumulator spring?? [Re: Lew] #458843
09/04/09 09:36 AM
09/04/09 09:36 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think w/ Man valve bodies it tells you to remove it.
Coming soon!!!!
Re: 727 acumulator spring?? [Re: Mr.Yuck] #458844
09/04/09 12:45 PM
09/04/09 12:45 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
yep, Turbo Action MVB instructions tell you to remove it. I think most of the shift kits say the same.
Re: 727 acumulator spring?? [Re: forphorty] #458845
09/04/09 12:54 PM
09/04/09 12:54 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
Leave it out.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: 727 acumulator spring?? [Re: forphorty] #458846
09/04/09 01:14 PM
09/04/09 01:14 PM
Az
Crizila Offline
Crizila  Offline
Az
They leave you the option - in or out depending on street or race.
Fastest 300
Re: 727 acumulator spring?? [Re: Lew] #458847
09/04/09 02:26 PM
09/04/09 02:26 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
The accumulator spring located between the accumulator piston and the valvebody cushions the application of the forward clutch. It does not cushion the 1-2 shift. Check the hydraulic diagrams. However, if you remove the spring AND install a blocker rod between the top of the accumulator bore and the piston to space down the piston, this WILL firm the 1-2 shift. Most shift kits say take it out as with RMVBs. When using a Griner RMVB or transbrake, the accumulator piston can be removed along with the spring.
John
Re: 727 acumulator spring?? [Re: 65dragnet] #458848
09/04/09 04:20 PM
09/04/09 04:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Oldest myth in the Mopar world, no matter how many times it's repeated and by whom it's still a myth.
There are only two logical reasons to remove the outer accumulator spring:
1) To install a blocker rod (blocking the piston is the ONLY accumulator mod that will firm up the 1-2 shift)
2) To shave off 2 ounces of weight
Leaving it in has the benefit of staving off a rear clutch failure.
Re: 727 acumulator spring?? [Re: John_Kunkel] #458849
09/04/09 05:19 PM
09/04/09 05:19 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
mine was removed years ago because thats what the shift kit told me to do. but theres no blocker rod in there. I believe the cheetah manual/automatic instructions said to leave the spring out as well. dont think it said anything about blocking it though.
so i dont have a spring in mine now.
Re: 727 acumulator spring?? [Re: John_Kunkel] #458850
09/04/09 05:37 PM
09/04/09 05:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
John , does it have an effect on the 2-3 shift ? That's the one that was the hardest hitting shift in my truck , BUT the clip that holds the boost valve on top of the VB was also broken and the valve was stuck in the open position , so I'm not really sure what softened my 2-3 ??
Re: 727 acumulator spring?? [Re: JohnRR] #458851
09/04/09 08:06 PM
09/04/09 08:06 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
How long is the blocker rod and what diameter?
Kevin
Re: 727 acumulator spring?? [Re: Twostick] #458852
09/04/09 10:36 PM
09/04/09 10:36 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
I use a 1/2" round stock about 3" long. Trial fit the valvebody on the case to make sure that the VB sits flush with the piston and blocker rod installed. If it does not, shorten the rod a little. Some people use aluminum tubing or solid round stock.
John
Re: 727 acumulator spring?? [Re: DusterW2] #458853
09/04/09 11:12 PM
09/04/09 11:12 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
use a solid piece, tubing will mushroom and or bend if you don't get the length right. the idea is to keep the piston from slamming up and down after spring removal
Re: 727 acumulator spring?? [Re: Lew] #458854
09/05/09 06:19 AM
09/05/09 06:19 AM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
thanks for all the repleys, good info, think ill leave it out.
Re: 727 acumulator spring?? [Re: Lew] #458855
09/05/09 09:41 AM
09/05/09 09:41 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
are you going to block it too? or just leave it floating?
Re: 727 acumulator spring?? [Re: JohnRR] #458856
09/05/09 08:02 PM
09/05/09 08:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nope, after the 1-2 shift is complete the accumulator piston remains at the end of its bore in the case during the 2-3 shift and doesn't leave there until the trans downshifts to 1st.
Re: 727 acumulator spring?? [Re: John_Kunkel] #458857
09/06/09 09:48 AM
09/06/09 09:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks , must have been something with that boost valve bracket being broken .
