engine builders, bearing clearance? #458656
09/03/09 09:00 PM
09/03/09 09:00 PM
ky
68roadrunner Offline OP
ky
what would be the best rod and main clearances, and do you run different weight oil with different clearances? this is a 499 stock rb block, eagle crank, eagle steel rods, milodon single line system, w/ hv oil pump. this is an all race motor, 6800 shift maybe more on 1/4 mile.thanks alot.
Re: engine builders, bearing clearance? [Re: 68roadrunner] #458657
09/03/09 09:58 PM
09/03/09 09:58 PM
minimum .001 per inch of journal diameter is generally safe. more info would be needed to make an actual recommendation though.
Re: engine builders, bearing clearance? #458658
09/03/09 10:16 PM
09/03/09 10:16 PM
ky
ky
what kind of info? 13-1 flat top around 615 gram piston, alky dominator, [Email]280@.050[/Email] 683 lift. indy -1 325cc runner. glide 1854lbs w/driver. thanks
no power adders
Re: engine builders, bearing clearance? [Re: 68roadrunner] #458659
09/04/09 12:32 AM
09/04/09 12:32 AM
Aluminum rods or steel? When it comes to bearing clearances your way better off having them a 1/2 thousnad to loose than 1/4 thousand to tight. Use what dram recommended Or looser BTW, I like thin oil also, 5w20 or 5w30, especially in a drag motor that never gets the oil hot
Re: engine builders, bearing clearance? [Re: Cab_Burge] #458660
09/04/09 03:23 AM
09/04/09 03:23 AM
gregsdart Offline
gregsdart  Offline
Ran my 499 a tad loose at .0027 to .0028 on the mains, rods about .0025 to .0027 aluminum rods. 20w50 oil, safest for the power level you will be at.
Re: engine builders, bearing clearance? [Re: 68roadrunner] #458661
09/04/09 08:14 AM
09/04/09 08:14 AM
NC
440Jim Offline
440Jim  Offline
NC
FWIW, I aim for 0.0030" on the mains (2.75" dia) and 0.0025" on the rods. Guys run them tighter and looser...
Re: engine builders, bearing clearance? [Re: 68roadrunner] #458662
09/04/09 08:19 AM
09/04/09 08:19 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
For your engine I would run about what the others have said, .0025-.003, with a thicker oil. Just an FYI on class engines I run about .0015 clearance with real thin oils.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: engine builders, bearing clearance? [Re: 440Jim] #458663
09/04/09 08:23 AM
09/04/09 08:23 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Race engines mostly like ..002+.We use .002/.0025 with multiviscosity synthetic oils and .003/.0035 with straight weight oils such as 40W,50W and 70W.
Re: engine builders, bearing clearance? [Re: B G Racing] #458664
09/05/09 10:39 AM
09/05/09 10:39 AM
ky
ky
if i go .003 on rods and mains both, and run a 50w or 20-50 oil this will be ok on a bracket motor? thanks guys
Re: engine builders, bearing clearance? [Re: 68roadrunner] #458665
09/05/09 10:58 AM
09/05/09 10:58 AM
NC
440Jim Offline
440Jim  Offline
NC
That does seem like a lot for the rods. Are you running steel rods or aluminum? Are they 2.200" or 2.375" journals? It will give more oil flow to the rods for cooling.
I wouldn't run straight 50 oil on a "mild" bracket motor unless you have a good reason. 20W-50 would be fine, IMO.
Re: engine builders, bearing clearance? [Re: 68roadrunner] #458666
09/05/09 11:42 AM
09/05/09 11:42 AM
I run those clearances or looser with thinner oil The single wieght oil can make as much as 10 HP loss or gain depending on oil temp. differences, that is why I run 5w20 or 5w30 in my motors now. 10 HP is usually a tenth of a second defference at the track
Re: engine builders, bearing clearance? [Re: 440Jim] #458667
09/06/09 11:04 AM
09/06/09 11:04 AM
ky
ky
steel eagle, 2.375 i suppose at .0025 i would be closer to the .001 per inch rule.
