Re: engine builders, bearing clearance?
[Re: 68roadrunner]
#458657
09/03/09 09:58 PM
09/03/09 09:58 PM
minimum .001 per inch of journal diameter is generally safe. more info would be needed to make an actual recommendation though.
[Re: 68roadrunner]
#458659
09/04/09 12:32 AM
09/04/09 12:32 AM
Posts: 43,244 Bend,OR USA
Cab_Burge
Aluminum rods or steel? When it comes to bearing clearances your way better off having them a 1/2 thousnad to loose than 1/4 thousand to tight. Use what dram recommended Or looser BTW, I like thin oil also, 5w20 or 5w30, especially in a drag motor that never gets the oil hot
[Re: Cab_Burge]
#458660
09/04/09 03:23 AM
09/04/09 03:23 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Ran my 499 a tad loose at .0027 to .0028 on the mains, rods about .0025 to .0027 aluminum rods. 20w50 oil, safest for the power level you will be at.
[Re: 68roadrunner]
#458662
09/04/09 08:19 AM
09/04/09 08:19 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
For your engine I would run about what the others have said, .0025-.003, with a thicker oil. Just an FYI on class engines I run about .0015 clearance with real thin oils.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: 68roadrunner]
#458665
09/05/09 10:58 AM
09/05/09 10:58 AM
Posts: 16,928 NC
440Jim
NC
if i go .003 on rods and mains both, and run a 50w or 20-50 oil this will be ok on a bracket motor? thanks guys
That does seem like a lot for the rods. Are you running steel rods or aluminum? Are they 2.200" or 2.375" journals? It will give more oil flow to the rods for cooling.
I wouldn't run straight 50 oil on a "mild" bracket motor unless you have a good reason. 20W-50 would be fine, IMO.
[Re: 440Jim]
#458667
09/06/09 11:04 AM
09/06/09 11:04 AM
Posts: 877 ky
68roadrunner
ky
steel eagle, 2.375 i suppose at .0025 i would be closer to the .001 per inch rule.
