Painting and wrapping headers
#458644
09/03/09 08:57 PM
09/03/09 08:57 PM
Posts: 102 Virginia
MACDiesel
Virginia
I'm replacing my super rusty flowtech headers with some not so rust hooker comps. They're obviously used but still have plenty of good metal. They're being sandblasted right now.
The plan is to paint them and then wrap them up in thermal tape. I'm planning on using VHT paint.
I keep hearing that you have to burn header paint in by running them on the engine and letting them smoke off.
Does anyone have experience with this stuff?
Am I going to have to install them twice? Once to burn them in and once to wrap them up.
-1967 Belvedere II 440/4speed
Re: Painting and wrapping headers
[Re: MACDiesel]
#458650
09/04/09 12:22 PM
09/04/09 12:22 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I get them as mechanically clean as I can - blast, sand, wire wheel, whatever, then clean them several times with laquer thinner. After spraying, I hang them from the port flanges and point a heat gun into the collector and let it run for about an hour, then into each port for about 15min each to "pre-cook" them before I install. It helps a lot with the smoke from startup.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: MACDiesel]
#458652
09/04/09 01:30 PM
09/04/09 01:30 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Painting is very short term, painting and wrapping will speed up the paint breakdown process and then heat fatique the header. Ceramic coating inside and out is the best longest term solution.
