Re: Hoosier Radial Slicks which ones?
[Re: 74DusterP457]
#458571
09/04/09 06:52 AM
09/04/09 06:52 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I run the M/T 31.25*12.2 radial slick on my Challenger. I have maybe 65 runs on them so far. Last weekend they went 1.342 in the 60'. They are the most consistant tire I have ever run, but when they start to spin look out. I try to turn them every other weekend, so maybe every 20 passes or so. They are quicker by about .10 for me.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: SuperStocker]
#458572
09/04/09 09:40 AM
09/04/09 09:40 AM
Posts: 2,946 Windsor ,Ca.
Keith Richards
Windsor ,Ca.
If you need help in the traction dept., use the softer compound, CO7. They will not last as long as the CO6's nor be quite as fast; at least that has been my experience. You do know that 30 X 9 Hoosiers come in two different circumferences, don't you?
The CO7's are firmer (harder) then the CO6's. You can look here at the bottom of the page at the chart.
http://www.hoosiertire.com/specdrag.htm
I have ran the 07's (30x9x15) and it is a great consistent tire. Just broke in a new set Wednesday night an in 5 passes I was 1.558, 1.558,1.548,1.551 and a 1.552 that was in 85 to 98 degree weather with 125+ track temps. 3400# car running 10.60's. Oh and my last set ran out of tread at 110 passes.
