QA1 Stocker Star AL single shock settings? #458456
09/03/09 05:45 PM
09/03/09 05:45 PM
Milwaukee, WI
joflaig Offline OP
joflaig  Offline OP
Milwaukee, WI
I searched but could not find, and have misplaced the original tech spec from QA1...anyway I'm headed to the track tomorrow and am not sure what I should I set the single adjustable knobs on the front and rear to. I don't want to bottom out the shocks or anything.
Anyone use these on their cars? What settings do you use? Do you make the right rear stiffer than the left rear?
Thanks!
Re: QA1 Stocker Star AL single shock settings? [Re: joflaig] #458457
09/03/09 06:18 PM
09/03/09 06:18 PM
My rear units could stand 4-5 clicks on a HOOKING track but I usually kept them at 3 clicks with my Hoosiers and they LOVED it--I ran Konis on the front so...BTW I was 002 003 SS spring Duster CM
I think they had up to 12 clicks total but it just loved three clockwise from zero
Re: QA1 Stocker Star AL single shock settings? [Re: joflaig] #458458
09/03/09 06:47 PM
09/03/09 06:47 PM
Whe run ours on the #2 setting
Re: QA1 Stocker Star AL single shock settings? #458459
09/03/09 09:27 PM
09/03/09 09:27 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
IIRC the instruction say to start W/ 4 on the front and 5 in the rear and then adjust for tthe conditions.
FWIW, I'm right now at 4 & 5
