Re: stall speed
[Re: UKDART]
#458405
09/03/09 04:54 PM
09/03/09 04:54 PM
Posts: 10,006 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If this will be strictly race, then stall should be about 1000 rpm lower than shift rpm. For a dual purpose combo, tighter for some lockup for cruising. You will lose some ET with a tighter converter. It pretty much boils down to how much slippage you are willing to tolerate, so be sure and give the converter builder an accurate description of what characteristics you want.
Re: stall speed
[Re: gregsdart]
#458406
09/03/09 07:00 PM
09/03/09 07:00 PM
You say it's running low 13's........at what speed??
Re: stall speed
[Re: UKDART]
#458408
09/04/09 08:44 AM
09/04/09 08:44 AM
terminal speed is around 105, 107 best he shifts at 5200 rpm
With a 10" PTC converter that stalls around 4,000 to 4,200, it'll run 12.50's to 12.30's even with the 3.55's.......AND still be completely driveable.........
