Re: Rear Shocks - Adjustibles,...which ones are best
[Re: ETASPEN]
#458222
09/03/09 11:08 AM
09/03/09 11:08 AM
Posts: 11,716 Portage,michigan
B3422W5
Portage,michigan
I think your going to find(at least in the world of shocks)that the more you spend, the better your results are going to be.
If i was looking at buying real good shocks(i currently run what you have) this would be my opinion...1 being better than what you have, and going up from there in quality
1. Ranchos 2. QA1'S 3 Strange 4. Afco's 5 Santuff's
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: LAR_414]
#458224
09/03/09 11:29 AM
09/03/09 11:29 AM
B3422W5
Portage,michigan
Do they adjust farther than 30/70 ? Seems like I need an even slower shock than that.
Things are pretty violent with a Stick! The shock load is pretty severe.
No, they dont,(30/70 40/60 50/50...i actually have mine staggered in the back, after playing with them over a period of time. prior to doing so my driver side rear tire would actually get air when i launched the car
[Re: B3422W5]
#458226
09/03/09 11:48 AM
09/03/09 11:48 AM
Posts: 3,746 Riverside, California
Lil Demon
I would put Koni DAs just before the Santhuff's
[Re: LAR_414]
#458228
09/03/09 12:26 PM
09/03/09 12:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Springs are Super Stocks (002 / 003). Front segment clamped all the way, rears have a few clamps. I could try clamping all the rear to keep separation down.
I could even add a leaf to both springs to make them stiffer.
THe first two runs, with the shocks set at 50/50 had me getting about 3" of air under BOTH rear tires at the same time. The car would hit the tires, they would flatten out some, and then bounce right back off the pavement. Just like a basketball.
Change the shocks to 30/70 and that really helped, along with lowering the air pressure some more.
I seem to be pretty close with the 30/70 setting and 17lbs in the tires. But I want to slow down the hit some more. I need more control back there.
You dont want the spring to hold you down, you want the shock to control the rise... so dont add any clamps to the rear segments... I have QA-1s singles that have 12 adjustments... I like them for a fairly inexpensive shock(mine are coil overs). To me I wouldnt use the Rancho's because they need to be at or near the max setting and that doesnt leave you much, if any adjustment..... JMO
[Re: ETASPEN]
#458231
09/03/09 02:33 PM
09/03/09 02:33 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Rancho's work great for me.
set on seven to start
[Re: Dodgem]
#458232
09/03/09 04:38 PM
09/03/09 04:38 PM
Posts: 370 Real North Cal.
66er
Real North Cal.
Mine are usally on 7. The 9 setting gives you more than a CE shock on 70\30, My rear axle sepparation is almost zero with the shocks on 9.
[Re: LAR_414]
#458238
09/04/09 12:44 PM
09/04/09 12:44 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Mancini is running a sale on Afco shocks.Last time I looked they had single and double adjustable units at very reasonable prices. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
