Re: Oil Pump Bypass Pressure Spring?
[Re: D_C]
#458101
09/03/09 03:43 AM
09/03/09 03:43 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
what engine?
have you ever seen how thin 5w30 oil is when its hot? if I lived in Cali, I would be running straight 30wt.oh darn I live in Wa and run 30wt...
I am truckless..
[Re: RapidRobert]
#458103
09/03/09 11:31 AM
09/03/09 11:31 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Oil pressure below the max output of any pump is controlled by bearing clearances. You can shim the relief, or replcae the spring, but it only affects the pressure that it bypass from. If the pump by pass is normally 75psi (which is where HV pumps typically are) then if it's only producing 50psi it's not in the bypass mode. So if you have 5psi at idle, you need tighter clearances or heavier oil. Std pumps usually by-pass around 50psi. Hp and HV pumps at 75-80psi.
[Re: moper]
#458104
09/03/09 12:06 PM
09/03/09 12:06 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Thanks. Appreciate the replies and information. This is the Factory AMC 304 V8 in my '79 CJ5 Jeep. The oil, when Hot, is very thin, almost water-like. Still, I really like using Synthetic motor oil. I suppose I could switch to 15W50, but at $7/Qt: Quote:
Product Description
Mobil 1 15W-50 is the most advanced performance synthetic engine oil designed to provide the cleaning power, wear protection and performance reserve to keep engines running smooth and clean.
Features and Benefits
Mobil 1 15W-50 is formulated with SuperSyn, an extra high-viscosity synthetic fluid, plus extra anti-wear additive to provide extra protection for severe service applications.
Mobil 1 15W-50 is recommended for high performance vehicles including turbocharged and supercharged engines where a thicker oil film is desired.
Mobil 1 15W-50 is also recommended for older valve train designs that may benefit from a higher level of anti-wear normally not required for newer generation vehicles.
Mobil 1 15W-50 will also provide better anti-wear protection for higher valve spring tensions in certain racing engines.
[Re: Dodgem]
#458106
09/03/09 02:28 PM
09/03/09 02:28 PM
D_C
Yes, I plan to swap the oil out soon. Is there any "commonly available" synthetic motor oil, of heavier weight/viscosity, than 20W50 or single-weight? As for the Rocker-arm shaft possibility, the AMC V8 does not use "Shafts." Instead, pivot-posts and "Bridges" are used between each cylinder Intake/exhaust pair.
[Re: D_C]
#458107
09/03/09 03:40 PM
09/03/09 03:40 PM
Posts: 25,793 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Red Line has 60 and 70WT synthetic racing oil.
[Re: Dodgem]
#458110
09/03/09 06:03 PM
09/03/09 06:03 PM
D_C
AMC (American Motors Corporation) AMC was an American automobile company formed by the 1954 merger of Nash-Kelvinator Corporation and Hudson Motor Car Company. At the time, it was the largest corporate merger in U.S. history, valued at US$198 million ($1.44 billion in 2006 dollars). When declining sales and the competitiveness of the United States auto market forced AMC to seek a partner in the late 1970s, the company formed an alliance with France's Renault. This lasted until March 2, 1987, when the Chrysler Corporation bought out AMC. AMC V8
[Re: D_C]
#458111
09/03/09 09:53 PM
09/03/09 09:53 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
It's probably not just the thin oil - AMC V8's have a history of low oil pressure from the aluminum pump body growing faster from heat than the steel gears, which opens up the clearences and lets pressure drop. Thick oil will probably help, at the expense of high oil pressure at start-up.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: moper]
#458112
09/03/09 10:52 PM
09/03/09 10:52 PM
DaytonaTurbo
Manitoba, Canada
If you're getting 5psi at idle that's got nothing to do with your bypass. However moper, my stock pump and my hv pump both bypassed at around the same pressure(75-80).
[Re: D_C]
#458113
09/03/09 11:17 PM
09/03/09 11:17 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Nothing wrong with 30-grade motor oil in a high performance application. As long as your not enderance racing for hours at a time or have really loose bearings, there's no reason to run a 50-grade motor oil.
50-grade motor oils made since in the sixties with the oil technology of that time, but today most oils are much more resistant against thermal break down and sharing effects.
Take advantage of today's technology, and the thinner more robust oils that can take a beating; free up some horsepower at the same time.
On a side note, the Mobil 1 5W-30 is an (SM) rated motor oil so it has low zinc and phosphorus. It's a decent oil if you're running a roller cam. But if your running a flat tappet cam, you may want to look for a higher zinc formula motor oil.
[Re: Evil Spirit]
#458114
09/04/09 02:34 AM
09/04/09 02:34 AM
D_C
Appreciate the latest replies. Quote:
It's probably not just the thin oil - AMC V8's have a history of low oil pressure from the aluminum pump body growing faster from heat than the steel gears, which opens up the clearances and lets pressure drop.
Yes, I have heard about this (AMC engines) in the past. I also read that (at idle) an engine doesn't "need" very much oil pressure. As long as it doesn't drop to and linger around Zero, and climbs with RPM you're usually Ok.
Typically, it sinks to around 10-PSI, but the longer at idle and hotter it is (ambient) it can dip down to 5 PSI. Also, the lifters get a bit noisier.
The Oil-Pump is only around a year old. The box it came in indicated it was the High-Performance, High-Volume version, but typically, the Highest pressure I see is around 45-PSI (summertime.)
[Re: D_C]
#458115
09/04/09 07:35 AM
09/04/09 07:35 AM
moper
Columbia, CT
Im not an AMC guru...lol. But I know the brands with the oil pump in timing covers do have issues on a regular basis. Some of the noises you're hearing are because the engine was never designed to run what you want to, plus there wear that a rebuild doesnt help, like lifter bores and the clearances of the oil pump housing. So if you want to run thin oil, I think it has the protection the engine needs... but it might "just be noisey".
