Re: How did the rear coilovers get bent?
[Re: Leigh]
#458032
09/02/09 11:29 PM
09/02/09 11:29 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
Aldan double adjustables. Both stems are bent, drivers side severely so. Been on the car since 1998, only bent after sent to the jerks at Aldan. Mis-alignment bushings have plenty of movement.
Aldan shocks are JUNK.....period....I wouldn't even put them on a street rod.
[Re: gregsdart]
#458035
09/04/09 06:14 AM
09/04/09 06:14 AM
Posts: 5,989 Anoka County, MN
Leigh
Anoka County, MN
The mystery solved! At least we know where the hook went. Are you planning on getting out this year yet?
Greg, you know me. If there is an available way to murk up a clear glass of water, I'll get it done. I'm hoping to try a time or two yet this year. The shock guy in Now Then has both sets. I should know some re$ult$ Tuesday.
