CHALLENGER DISC BRAKE SET UP HELP #457876
09/02/09 09:21 PM
09/02/09 09:21 PM
pa
FOXY312 Offline OP
FOXY312  Offline OP
pa
I AM DOING A DISC BRAKE SET UP ON A 1970 CHALLENGER I AM USING 73 A-BODY SPINDLES AND NEW CAPLIPERS AND ROTORS I LIKE TO KNOW IF THERE WILL BE ANY PROBLEMS WITH THIS SET UP.
Re: CHALLENGER DISC BRAKE SET UP HELP [Re: FOXY312] #457877
09/02/09 09:53 PM
09/02/09 09:53 PM
AndyF Offline
AndyF  Offline
Should bolt right on there. Basically that is just putting a '73 E body disc setup onto the earlier E body.
Re: CHALLENGER DISC BRAKE SET UP HELP [Re: AndyF] #457878
09/02/09 10:11 PM
09/02/09 10:11 PM
BDW Offline
BDW  Offline
Re: CHALLENGER DISC BRAKE SET UP HELP [Re: FOXY312] #457879
09/02/09 10:21 PM
09/02/09 10:21 PM
As said a bolt on deal & check (hose routing/location). On your '70 if the hard line locating tab if it is in front or behind the spindle as F body calipers MAY have a more advantageous hose mounting location on the caliper than A body ones for the best hose routing. Get an idea of what you need & have your parts house set out both of em to compare. EDIT and related to hose routing, the spindles/calipers can be switched for side to side. Mock everything up & get the best fit you can.
Re: CHALLENGER DISC BRAKE SET UP HELP [Re: RapidRobert] #457880
09/03/09 09:32 PM
09/03/09 09:32 PM
pa
FOXY312 Offline OP
FOXY312  Offline OP
pa
CAN I CHANGE THE A-BODY SPINDLES AROUND SO THE CALIPER ARE MOUNTED IN THE BACK INSTEAD OF THE FRONT OR CAN I GET STEEL BRAID LINES.
Re: CHALLENGER DISC BRAKE SET UP HELP [Re: FOXY312] #457881
09/03/09 11:03 PM
09/03/09 11:03 PM
yes
