Least amount of oil pressure when pushrod oiling a B/RB #457646
09/02/09 05:25 PM
09/02/09 05:25 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Whats the least amount of oil pressure you guys running when pushrod oiling a big block?
I have a 572 with 572-13 heads and a dual line milodon system i am running around 8 to 10 psi at an idle when the motor is hot after a pass with 20w50 oil
It has 75 psi going down the race track.
I have cut 4 oil filters apart now after 60 passes on the motor and its not showing any signs of hurting anything.
Would you be worried or let it eat the way it is for the rest of the year.
And no the lifter bores are not bushed and it is a mega block.
Thanks.
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: sc301v] #457647
09/02/09 05:31 PM
09/02/09 05:31 PM
thats very low to me but its just idling, going down the track is where you want it.,
im thinking bearing clearance issues.
mine idles at 60psi hot 75 going down the track and 80 psi cold on my motor.
Re: Least amount of oil pressure when pushrod oiling a B/RB #457648
09/02/09 06:06 PM
09/02/09 06:06 PM
ok
mopdragster Offline
mopdragster  Offline
ok
My 540 B-1 did the same thing 80lbs cold 20lbs hot after a run at 1000rpm idling back. I put restrictors in the pushrods .030 and now it is 35 lbs hot idling with 20-50 val racing. It was always 80 on racetrack. I also checked the filters and was clean but I would be scared 2 death of 10lbs at idle even in a stock motor. But I am a wimp when it comes to oil pressure.
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: mopdragster] #457649
09/02/09 06:43 PM
09/02/09 06:43 PM
UK
602heavy Offline
602heavy  Offline
UK
Had the same problem , 605" megablock with 572-13 heads , i ended up plugging the oil way on gallery side of lifter & using the lifter bore as the restriction , i now have 25/30lb @ idle , 60/70lb down track.
I purchased the motor with a spun rod bearing , maybe this was the cause.
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: 602heavy] #457650
09/02/09 08:10 PM
09/02/09 08:10 PM
NC
440Jim Offline
440Jim  Offline
NC
I would turn the idle rpm up to get more oil pressure until the end of the season and then restrict oil to the heads.
FWIW, I run 10W-30 oil with all bracket racing going round-robin after 3rd round every week. I would change things in your motor over the winter. (bearing clearance, oil passages whatever is needed.)
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: 440Jim] #457651
09/03/09 08:23 AM
09/03/09 08:23 AM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
All bearing clearances where all dead on in the middle of the specs.It is an aluminum rod motor so i know i will lose a little there.
Whats the best way to restrict the oil to the heads on this setup..I dont care to go ahead and do it cause i will be racing until the end of November at least.
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: sc301v] #457652
09/03/09 09:00 AM
09/03/09 09:00 AM
ok
mopdragster Offline
mopdragster  Offline
ok
I would send the pushrods in and have them restricted. It is cheap fast and reversible if you decide it didn't help. Mine has bushed lifter bores with a .070 hole in bushing not lined up with the hole in the lifter and I still had oil pressure problem but mine just has a std volume oil pump. Gonna change that this winter.
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: mopdragster] #457653
09/03/09 09:11 AM
09/03/09 09:11 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
what rpm are you idling at?
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: bonefish] #457654
09/03/09 09:38 AM
09/03/09 09:38 AM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Around 12 to 1300 in gear.
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: sc301v] #457655
09/03/09 10:40 AM
09/03/09 10:40 AM
I don't know the best way but I used a piece of .080 bracing rod and made a L out of it so it would fit into and under the fitting in the head so it stuck up into the fitting the line attaches onto. I hope this makes sense Quick, easy and removeable
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: Cab_Burge] #457656
09/03/09 11:06 AM
09/03/09 11:06 AM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
The 572-13 heads doesn't have any external lines like the -1 heads do..Thats why im not sure how to restrict them.
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: sc301v] #457657
09/03/09 11:48 AM
09/03/09 11:48 AM
My bad, I wasn't aware of that How about using a press in bushing or epoxy a jet or some other orifice that will fit into the oil passage feeding the rockers or are they pushrod oiling only?
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: Cab_Burge] #457658
09/03/09 12:08 PM
09/03/09 12:08 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Yea it's pushrod oiling only with jesel rockers
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: sc301v] #457659
09/03/09 12:32 PM
09/03/09 12:32 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
yeh 10lbs is a little low.im thinking about a similar combo,keep us posted.
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: bonefish] #457660
09/03/09 01:15 PM
09/03/09 01:15 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Im gonna check the pushrods tonight..I told Manton to restrict them to .030 but im starting to wander if maybe they restricted them down .030 from the origanal size which would make them around .090.
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: sc301v] #457661
09/03/09 05:53 PM
09/03/09 05:53 PM
NJ
arc Offline
arc  Offline
NJ
is the block bushed and if it is what size hole in the bushing we use a .030 hole in the bushing
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: arc] #457662
09/03/09 08:08 PM
09/03/09 08:08 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Just checked th restrictor and indeed it's a .030.
ARC the block is not bushed..
So know what should my next step be?
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: sc301v] #457663
09/03/09 08:36 PM
09/03/09 08:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
There isnt much you can do.... more flow or thicker
oil... remember pressure is a by-product of flow due
to restriction ... so hopefully you still have good
flow to the bearings(just not much pressure)... have
you checked it with another gauge
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: sc301v] #457664
09/03/09 08:38 PM
09/03/09 08:38 PM
Livonia Michigan
440dart Offline
440dart  Offline
Livonia Michigan
Install an oil cooler that should help until you have a chance to go through the motor
Yes I live in Michigan, so there is still 1 light on
Re: Least amount of oil pressure when pushrod oiling a B/RB [Re: sc301v] #457665
09/03/09 09:42 PM
09/03/09 09:42 PM
NJ
arc Offline
arc  Offline
NJ
I have 15 at idle after a pass but i have alu block the only thing I would watch is the pushrod tips 2 see if they are getting blue I think u are bleeding around the lifters on next rebuild bush the block its worth the 600 dollars
