What Will It Run
#457321
09/02/09 08:21 AM
09/02/09 08:21 AM
Posts: 6,295 U.S.
moparniac
U.S.
Mopar Performance
Re: What Will It Run
[Re: moparniac]
#457322
09/02/09 09:08 AM
09/02/09 09:08 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
lobe separation? intake carb and headers? Tire frying mid 11's or a true shot at 10.6 or better depending on weather and altitude?? should be a kind of car!
[Re: moparniac]
#457327
09/02/09 10:27 AM
09/02/09 10:27 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Traction problems will haunt you. Motor should run really strong.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Jacob Pitt]
#457328
09/02/09 10:28 AM
09/02/09 10:28 AM
Posts: 6,295 U.S.
moparniac
U.S.
Im gonna run the 2.25 intake also....
Mopar Performance
[Re: moparniac]
#457329
09/02/09 10:37 AM
09/02/09 10:37 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Sounds like a very solid build to me. You can reduce bob weight with the 4.25 x 2.2 chev big end crank journal, but if you already have the 4.15 stroke crank it wouldn't be worth switching. Should make gobs of torque peaking below 5000 for sure. My WAG is 725 hp on pump gas, enough to put you solidly in the nines with some bite. I really like the aluminum block for a streeter, we fight to get all the weight we can off the front and you are starting with a motor lighter than a small block. Still, anything you can do to mount the motor as far back as you can will help. You might only get an inch or so, but it is worth the effort.
[Re: moparniac]
#457330
09/02/09 10:47 AM
09/02/09 10:47 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I like it. I might would take Greg's advice and make it a 540" w/ a 4.25" stroke and 4.5" bore. The cam is a little on the small side, but it'll be a good street motor and make gobs of power. CHIP
[Re: Quicktree]
#457332
09/02/09 11:30 AM
09/02/09 11:30 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Another vote for the 4.5 bore x 4.250 stroke here. Sounds good though
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: moparniac]
#457335
09/02/09 12:33 PM
09/02/09 12:33 PM
Dodgem
Ontario, Canada
I would go 4.375 bore/4.500 stroke for a reliable 540"
not that im arguing with you bob but I always thought the bigger arm would hurt longevity!
I dont wanna have to run the 572" setup and the indy 572-13 heads and a giant roller..... just not my thing.....
440-1's work just fine on a 572. (same bore????) just a bit bigger roller?? or not even change cam when you get tired?? for the same money why not have the extra 44 inches now and not be pining for them later. Then when you want more it's valve springs and a bigger cam to unlock a tone of unused potential
[Re: moparniac]
#457336
09/02/09 12:37 PM
09/02/09 12:37 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
Well I pulled the trigger and got a World aluminum short block and didnt wanna go too many cubes cause its 90% street car... after reading 8000+ of you guys arguments here is the route Im going
528" World Aluminum Block 4.500 bore/4.150 stroke 260/266 @ 50 Solid Roller Full Port Indy -1's (325 port volume) 93 Pump Gas 11 to 1 ET Street Radials 315/60/15 3400lb ??? race weight 71 Dart Caltracs Dana 60 4.10's Milodon Gear Driven 2 - 2 1/8th New Proparts/Mazzolinis 727 Custom Dominator All Motor for now
I think you will run low 10s w/that combo. Be a good combo for twin turbos some day..
[Re: B1Fish540]
#457337
09/02/09 05:18 PM
09/02/09 05:18 PM
Posts: 6,295 U.S.
moparniac
U.S.
I went 10.6 only time out with a 3850lb challenger with less head and 499 cubes.... I should come in at 400+ pounds lighter with more head and bigger cam and 30 more cubes.... The cam in the challenger was a 248/254 @ 50 roller..... I am shooting for 9's in 100% street trim! the way she sits is the way I want her to run at the track
Mopar Performance
