What Will It Run #457321
09/02/09 08:21 AM
09/02/09 08:21 AM
U.S.
moparniac Offline OP
U.S.
Mopar Performance
Re: What Will It Run [Re: moparniac] #457322
09/02/09 09:08 AM
09/02/09 09:08 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
lobe separation? intake carb and headers?
Tire frying mid 11's or a true shot at 10.6 or better depending on weather and altitude??
should be a kind of car!
Re: What Will It Run [Re: Dodgem] #457323
09/02/09 09:28 AM
09/02/09 09:28 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Dam an aluminum block. Why not build it 572 same money a bigger cam driveable pump gas and real shot at (9.99 ) (NOS is for girls and kids)
Re: What Will It Run [Re: Dodgem] #457324
09/02/09 09:30 AM
09/02/09 09:30 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I would go 4.375 bore/4.500 stroke for a reliable 540"
Re: What Will It Run [Re: Dodgem] #457325
09/02/09 10:07 AM
09/02/09 10:07 AM
U.S.
U.S.
New Style proparts 2 - 2 1/8th / custom dominator and I went 10.6 with indy ez's only 1 time out in a 3850 lb e body ...
Mopar Performance
Re: What Will It Run [Re: B G Racing] #457326
09/02/09 10:09 AM
09/02/09 10:09 AM
U.S.
U.S.
not that im arguing with you bob but I always thought the bigger arm would hurt longevity!
I dont wanna have to run the 572" setup and the indy 572-13 heads and a giant roller..... just not my thing.....
Mopar Performance
Re: What Will It Run [Re: moparniac] #457327
09/02/09 10:27 AM
09/02/09 10:27 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Traction problems will haunt you. Motor should run really strong.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: What Will It Run [Re: Jacob Pitt] #457328
09/02/09 10:28 AM
09/02/09 10:28 AM
U.S.
U.S.
Im gonna run the 2.25 intake also....
Mopar Performance
Re: What Will It Run [Re: moparniac] #457329
09/02/09 10:37 AM
09/02/09 10:37 AM
gregsdart Online content
gregsdart  Online Content
Sounds like a very solid build to me. You can reduce bob weight with the 4.25 x 2.2 chev big end crank journal, but if you already have the 4.15 stroke crank it wouldn't be worth switching. Should make gobs of torque peaking below 5000 for sure. My WAG is 725 hp on pump gas, enough to put you solidly in the nines with some bite. I really like the aluminum block for a streeter, we fight to get all the weight we can off the front and you are starting with a motor lighter than a small block. Still, anything you can do to mount the motor as far back as you can will help. You might only get an inch or so, but it is worth the effort.
Re: What Will It Run [Re: moparniac] #457330
09/02/09 10:47 AM
09/02/09 10:47 AM
an8sec70cuda Offline
I like it. I might would take Greg's advice and make it a 540" w/ a 4.25" stroke and 4.5" bore. The cam is a little on the small side, but it'll be a good street motor and make gobs of power. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What Will It Run [Re: an8sec70cuda] #457331
09/02/09 11:20 AM
09/02/09 11:20 AM
Q
Quicktree Offline
Quicktree  Offline
Q
fast enough to run you over and kill you if your not careful. good choice of parts on the motor I think. it will be plenty fast if your car can handle the power.
Re: What Will It Run [Re: Quicktree] #457332
09/02/09 11:30 AM
09/02/09 11:30 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Another vote for the 4.5 bore x 4.250 stroke here.
Sounds good though
Re: What Will It Run [Re: Bob_Coomer] #457333
09/02/09 11:38 AM
09/02/09 11:38 AM
Sounds good though
If you already have the crankshaft you can have it offset ground down to the BB Chevy rod size and make the stroke 4.25 or even 4.300 like the one in my 518 low deck is I like the cam you chose, it sounds like the one in my 518 also My cam makes peak HP(with the six pak) at 5800 RPM and peak torque at 4500 RPM, it is a torque monster
Re: What Will It Run [Re: Cab_Burge] #457334
09/02/09 12:23 PM
09/02/09 12:23 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Congrats and that is the way to go The only thing I would add is if you want to go nitrous later, contact Monte now and build the motor for that Mid 8's with what you have.Good luck.
Re: What Will It Run [Re: moparniac] #457335
09/02/09 12:33 PM
09/02/09 12:33 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
440-1's work just fine on a 572. (same bore????)
just a bit bigger roller?? or not even change cam when you get tired?? for the same money why not have the extra 44 inches now and not be pining for them later. Then when you want more it's valve springs and a bigger cam to unlock a tone of unused potential
Re: What Will It Run [Re: moparniac] #457336
09/02/09 12:37 PM
09/02/09 12:37 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Well I pulled the trigger and got a World aluminum short block and didnt wanna go too many cubes cause its 90% street car... after reading 8000+ of you guys arguments here is the route Im going
528" World Aluminum Block
4.500 bore/4.150 stroke
260/266 @ 50 Solid Roller
Full Port Indy -1's (325 port volume)
93 Pump Gas
11 to 1
ET Street Radials 315/60/15
3400lb ??? race weight 71 Dart
Caltracs
Dana 60 4.10's
Milodon Gear Driven
2 - 2 1/8th New Proparts/Mazzolinis
727
Custom Dominator
All Motor for now
I think you will run low 10s w/that combo. Be a good combo for twin turbos some day..
Re: What Will It Run [Re: B1Fish540] #457337
09/02/09 05:18 PM
09/02/09 05:18 PM
U.S.
U.S.
I went 10.6 only time out with a 3850lb challenger with less head and 499 cubes.... I should come in at 400+ pounds lighter with more head and bigger cam and 30 more cubes.... The cam in the challenger was a 248/254 @ 50 roller..... I am shooting for 9's in 100% street trim! the way she sits is the way I want her to run at the track
Mopar Performance
