Oil pan w/ hole for drag link #457024
09/01/09 10:47 PM
09/01/09 10:47 PM
CHANDLER, AZ
512 VALIANT Offline OP
CHANDLER, AZ
Anyone run one w/ an A-body? Or have any pics? How do they work, any problems?? I will need 1 w/ new combo in order to run dual line ext oil pump, w/ stock k-member and no rack. THX
Re: Oil pan w/ hole for drag link [Re: 512 VALIANT] #457025
09/01/09 10:52 PM
09/01/09 10:52 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
You'll need solid mounts or an engine plate to keep engine movement
from locking the steering.
My SB pan is 11" deep...........they hang loooooow!
Re: Oil pan w/ hole for drag link [Re: S/ST 3040] #457026
09/01/09 10:57 PM
09/01/09 10:57 PM
CHANDLER, AZ
CHANDLER, AZ
Thx its a 512 inch b-block and it is plated front and mid.
Re: Oil pan w/ hole for drag link [Re: 512 VALIANT] #457027
09/01/09 11:46 PM
09/01/09 11:46 PM
I have run one in a Duster, we made it out of steel (and welded onto a stock pan with the bottom cut off) with a long sump with the dual line external pick up mounted behind the steering linkage tube. We would put a stock oil pan on the motor to install it due to the long sump not clearing the stock K member until the motor was in the car We (several people owned and raced that car besides me )would install the motor, remove the drag link and then the oil pan, install the big oil pan, hook the oil system up and hook the steering back up, pain in the rear I have several aluminum oils pans with the tubes welded into them, one is on a motor that will go into my Duster soon This pan is a Charlies Oil Pan brand that I bought used and sent it back to him to make it fit my motor in my car, my motor is set back a little more than most A bodys with BB That is the reason the upper front corner is square instead of being round like the rest of the tube IHTHs
Re: Oil pan w/ hole for drag link [Re: Cab_Burge] #457028
09/12/09 03:13 PM
09/12/09 03:13 PM
CHANDLER, AZ
CHANDLER, AZ
Thanks for the info. Mine is set back pretty far as well and also a little low. The Milodon pan w/ the hole it will not work w/ my motor plates the drag link still runs into the pan. Is there any pitman or idler arms that have a longer reach or lower than the stock ones (factory slant 6 car)??
Then I guess my worry would be the oil pan sits to low and may have contact w/ the ground when the front end comes back down, after the launch.
Re: Oil pan w/ hole for drag link [Re: 512 VALIANT] #457029
09/12/09 03:31 PM
09/12/09 03:31 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have seen modified center links.Cut to fit and reweld
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Oil pan w/ hole for drag link [Re: hemi-itis] #457030
09/12/09 04:16 PM
09/12/09 04:16 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Milodon, rectangle hole. Center link center replaced with a straight section of solid steel, welded with consecutive penetrations, from deep to surface. I considered threading the cut off ends, and using a piece of moly, but ended up having it welded instead.
Re: Oil pan w/ hole for drag link [Re: Leigh] #457031
09/12/09 04:24 PM
09/12/09 04:24 PM
CHANDLER, AZ
CHANDLER, AZ
Thanks do you have a pic. I would love one. Thx
Re: Oil pan w/ hole for drag link [Re: 512 VALIANT] #457032
09/12/09 05:48 PM
09/12/09 05:48 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Best to mock one up with the motor & link in the car, and pay attention to the crossmembers. My SB Duster has a huge Billet Fab pan in it, and I can pull & reinstall it in minutes, including pulling the drag link. No big deal. I marked my balancer so I can have the crank throws in the right place to clear the front of my pan where it's also close to the K.
Re: Oil pan w/ hole for drag link [Re: 512 VALIANT] #457033
09/12/09 07:52 PM
09/12/09 07:52 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Small block or bb?
Post deleted by Defbob [Re: 512 VALIANT] #457034
09/12/09 09:57 PM
09/12/09 09:57 PM
Re: Oil pan w/ hole for drag link #457035
09/12/09 10:05 PM
09/12/09 10:05 PM
rowin4 Offline
rowin4  Offline
Fred, didn't you make or have a picture of a a-body bb pan with a drag link tube in it?
Post deleted by Defbob [Re: rowin4] #457036
09/12/09 10:17 PM
09/12/09 10:17 PM
Re: Oil pan w/ hole for drag link #457037
09/12/09 10:31 PM
09/12/09 10:31 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Heres my junk.. Need more I can get them for ya.. Let me know what you want to see...
Re: Oil pan w/ hole for drag link [Re: 70dusterjohn] #457038
09/16/09 11:43 PM
09/16/09 11:43 PM
CHANDLER, AZ
CHANDLER, AZ
AWSOME!!!!! Thx
sorry for delay I was on vacation.
Re: Oil pan w/ hole for drag link [Re: 512 VALIANT] #457039
09/17/09 08:35 AM
09/17/09 08:35 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I had a Milodon pan on my small block Dart for a few years, because my car sits low we had to have the draglink tube moved lower in the pan it worked and looked good but was a hassle every time I took the motor out and I eventually went to a Moroso pan.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
