Question about Sunoco Maximal 116 race gas....... #456785
09/01/09 08:40 PM
09/01/09 08:40 PM
State of confusion
Thumperdart Offline OP
State of confusion
A friend of mine has many gallons of this stuff and said he`d give me 5-gallons to try and see how I like it for an upcoming street race so, at my 12.11 compression would this be way too much or can you mix it w/pump to dilute it a bit. Anybody try this stuff and will it work for me? Thankxx in advance....
Re: Question about Sunoco Maximal 116 race gas....... [Re: Thumperdart] #456786
09/01/09 09:08 PM
09/01/09 09:08 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
I have run it in my 14.8:1 motor - my car actually slows down on it compared to VP C14+. I thought it could be overkill for mine - but I guess not.
Re: Question about Sunoco Maximal 116 race gas....... [Re: Lil Demon] #456787
09/01/09 09:18 PM
09/01/09 09:18 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
It is very good fuel, especially for nitrous motors. We ran it in a 16:1 two stroke race engine with great success.
I may be trying it soon in my big motor.
I would not recommend mixing it
Re: Question about Sunoco Maximal 116 race gas....... [Re: MegaDart] #456788
09/01/09 09:50 PM
09/01/09 09:50 PM
NW Pa.
KD800X Offline
KD800X  Offline
NW Pa.
VP C14 has a MON number of 114, VP C14+ has a Mon number of 115 and Sunoco Maximal 116 has a Mon number of 114. So Maximal is real close to the VP, the RON number is 116. We are running the Sunoco Maximal 116 And like it. I can't say it's better or worse than VP.
Unless you are running 14:1 or more I don't see a reason to run it.
Re: Question about Sunoco Maximal 116 race gas....... [Re: KD800X] #456789
09/02/09 12:00 AM
09/02/09 12:00 AM
State of confusion
State of confusion
Thankxx guys..........That`s why I asked! I just figured if mixed, it would have an octaine that would be more suitable for my semi-low compression. The 91 crap I`m stuck w/at the pump just falls shy in my opinion when I step on the loud pedal and don`t want to hurt it.
Re: Question about Sunoco Maximal 116 race gas....... [Re: Thumperdart] #456790
09/02/09 06:36 AM
09/02/09 06:36 AM
Lehigh Acres, Florida
rickstershemi Offline
Try Sunoco 110
Rickster
Re: Question about Sunoco Maximal 116 race gas....... [Re: Thumperdart] #456791
09/02/09 06:47 AM
09/02/09 06:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats gonna be WAY too much octane for your engine...
you could blend it down... I use to run 114 and switched
to 112 and picked up with no other changes(14.1:1)
now running E-85
Re: Question about Sunoco Maximal 116 race gas....... [Re: Thumperdart] #456792
09/02/09 06:58 AM
09/02/09 06:58 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It's more than your 12-1 motor needs, but it won't hurt the motor if you ran it straight. I would not hesitate blending it with some other straight gas. I sell it and have burned a bunch of it.
Re: Question about Sunoco Maximal 116 race gas....... [Re: rickstershemi] #456793
09/02/09 06:46 PM
09/02/09 06:46 PM
State of confusion
State of confusion
Thankxx again and right now I blend trick 110 w/91 at about a 50/50 mix and it runs well but just figured I`d ask and since he said I could have five gallons to try.
Re: Question about Sunoco Maximal 116 race gas....... [Re: Thumperdart] #456794
09/02/09 06:57 PM
09/02/09 06:57 PM
Q
Quicktree Offline
Quicktree  Offline
Q
mix it the same way and let it ride
Re: Question about Sunoco Maximal 116 race gas....... [Re: Quicktree] #456795
09/02/09 07:14 PM
09/02/09 07:14 PM
State of confusion
State of confusion
So Quick, does it mix ok w/pump unleaded as far as you know and does it seperate or do any weird stuff when not driven for a while? Thankxx.
Re: Question about Sunoco Maximal 116 race gas....... [Re: Thumperdart] #456796
09/02/09 07:18 PM
09/02/09 07:18 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have mixed it before but I reaaly don't know if it does anything weird. it ran fine for me. I usually jut mix 110 though
Re: Question about Sunoco Maximal 116 race gas....... [Re: Quicktree] #456797
09/02/09 08:19 PM
09/02/09 08:19 PM
mix it, i have been doing it for 4 years now with no problems. maximal with 93 octane,
Re: Question about Sunoco Maximal 116 race gas....... #456798
09/03/09 02:57 PM
09/03/09 02:57 PM
State of confusion
State of confusion
Thankxx for the confirmation......what percentage do you mix at and at what comp. Thankxx....
