Re: 360/904 torque converter
[Re: GasHog72]
#456770
09/01/09 08:45 PM
09/01/09 08:45 PM
RapidRobert
any 904 converter from the earliest 360 (71-72) up to when the lockup trannies were introduced in ~76-77 as the converters became different also to fit the lockup trans input shaft that now had a smooth non splined area on the end of the splines whereas the older non lockups were splined to the tip.
[Re: MoparforLife]
#456772
09/02/09 07:56 AM
09/02/09 07:56 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
or if you use the B&M weighted flexplate, any neutral balance (318), non lockup 904/998/999 converter will fit. including the one you probably already own.
