Re: Fan noise fron fan blade on 440
[Re: mc4406]
#456699
09/01/09 07:14 PM
09/01/09 07:14 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Not sure about the noise. Sounds plausible. I've had flex-fans on vehicles in the past and some were noisier.
In any event, I would visually inspect the fan, pullies, belts for wear, cracks, bent blades, balance.
Would also add an aftermarket fan-clutch if space allows. That may "fix" the noise, and it should improve fuel-economy, performance, wear on engine.
[Re: mc4406]
#456702
09/01/09 07:36 PM
09/01/09 07:36 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Fan noise is mostly dependent on the width/pitch of the blades, a more agressive pitch moves more air but with the accompanying noise. A clutch fan with the same diameter/pitch as a direct drive will make less noise.
I'd change over to a clutch fan like most A/C equipped cars.
