Re: Bob Wieght... Is this light? Crank BILLET vs Forge??
[Re: Diablo]
#456575
09/01/09 10:28 PM
09/01/09 10:28 PM
either crank will get the job done. can you post the individual weights of the components to get that bob weight? sounds pretty light.
[Re: Diablo]
#456576
09/01/09 10:28 PM
09/01/09 10:28 PM
Posts: 243 NJ
arc
NJ
bryant is the only way to go but 1777 cant be the bob wt i have done many of these motors with 7.1 mgp rods the bob wt of 2050 is more like it http://www.youtube.com/watch?v=yuYVxeW474U
[Re: arc]
#456577
09/01/09 10:39 PM
09/01/09 10:39 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
My rods, pistons, rings, pin and bearings weigh in at 1047. 6.200 billet carrillo, 4.185 bore 1.175 CH 1567 BW These are small block parts though
[Re: Diablo]
#456579
09/01/09 11:16 PM
09/01/09 11:16 PM
Posts: 243 NJ
arc
NJ
Ok am i missing something?
When i put my piston, rings, bearing, pin, rod on the scale it read 1777grams (ill double check tomorrow) is there a calculation to find the BW???
ch of 1.1 is scary u might wont to get a 7.00 rod
[Re: Diablo]
#456580
09/01/09 11:19 PM
09/01/09 11:19 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
I think the bob weights consist of half the rod weight(I'm not sure which end?), rod bearings, piston with pin and rings and some oil. I'm not a machinest or a qualified engine balancer tech, but that is what I remember from various discusions on bob wieght, hopefully one of the more knowledgabe techs will chime in and correct me as needed or verify what the correct desription of the bob weight is
[Re: Diablo]
#456582
09/01/09 11:37 PM
09/01/09 11:37 PM
DemonDust
Menomonee Falls
Rotating weight (both big rod ends and rod bearings)+ recipricating weight (piston, pin, locks, rings, oil, Small end weight)
[Re: DemonDust]
#456584
09/02/09 10:15 AM
09/02/09 10:15 AM
Posts: 3,441 Mo.
supercomp
Mo.
