Whats wrong with the launch???
#456415
09/01/09 12:56 PM
09/01/09 12:56 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
In this video, you will notice the left front tire lift slightly, then it comes straight back down before the car moves forward.. Anyone have an idea what causes this? The motor is running flawless with no lag, no bog and no stumble.. http://www.youtube.com/watch?v=h5ldsn0aoh8
Re: Whats wrong with the launch???
[Re: Cab_Burge]
#456419
09/01/09 02:28 PM
09/01/09 02:28 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
tell us about it. you have the old hook spin hook front end does not transfer well. minimum 50/50 drag shocks better ranchos set at 7 or 8 cal trac 90/10s out front??
second look see you have cal tracks but your front end had next to 0 movement???
[Re: formula S]
#456423
09/02/09 03:46 PM
09/02/09 03:46 PM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
Cab , are you saying : with the rear tires of the ground the bottom of the shackel should be angled to the back of the car. Mine is angled to the front about 6*. This could be my problem with traction.
Sheldon
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
