Re: Mopar Torque Converters
[Re: SPWC]
#456154
09/01/09 07:24 AM
09/01/09 07:24 AM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
Just like in politics, you can't believe everything that you hear.
This is the land of the free
because of the brave
[Re: dulcich]
#456155
09/01/09 11:01 AM
09/01/09 11:01 AM
Posts: 4,102 Cochise County Arizona
SPWC
You can't believe everything that some random guy might tell you - that's certainly not the right way to get knowledgeable on a subject. Mopar made many different OEM converter configurations, some that were excellent hight-stall street units. In fact, Mopar was a pioneer in the field of performance conveters.
I understand this,but this came from the mouth of a guy thats very well known as "The Mopar guy" in town.He was the same guy that kept referring to my 78 Cordoba as a C body. I corrected him and he stated that after 1974,ALL Fullsize Mopars were on the C body platform.
Yeah now I understand why a few certain people say they wouldnt do business with the guy and that hes really full of himself.
[Re: SPWC]
#456158
09/01/09 01:40 PM
09/01/09 01:40 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
In one sense, all the major automakers sourced parts from outside manufacturers. Sometimes identical components, wound up on different makes. That said, sounds like he is generally full of it, and not just himself.
In future dealings, you could always find written proof, from several sources, that contradict what he has to say and confront him. Of course, he will continue to just dodge and weave and make excuses, but he'll eventually realize you're not so easily fooled.
You don't need to be Nasty about it, just factual. If you do it in front of other people, be prepared for a battle, as his ego will be on the line.
Now that you know he's really a false-expert, keep what he says with that in mind. If you suspect he's wrong, look it up or ask here.
If he's really that full-of-himself, others have or will recognize it. In the future, you could be cordial, but generally avoid him.
Over time, if you stick with it, read and look into the subject, you'll gain your own expertise. It simply takes time, but you're on the right track.
[Re: Mr.Yuck]
#456160
09/01/09 02:06 PM
09/01/09 02:06 PM
Posts: 216 united kingdom
Simonic
united kingdom
So now we know that your expert isn't one at all,how about torque convertors? What were the 'good'torque convertors? Are there any 'dogs' to avoid? Do torque convertors have part numbers? Do the hi-po cars(r\t's six packs etc)have a hi stall convertor? I must admit when i put my new engine in i never even looked at the convertor,so i don't know much about them at all. School us please
Keeping the Bee Buzzin'
[Re: Simonic]
#456161
09/01/09 03:25 PM
09/01/09 03:25 PM
Posts: 15,487 Florida
scratchnfotraction
I went from a "stock low stall tc" to a "stock high stall tc" in a lot of mopar trannys mopar was good about duel purpose tc and depends on what it was in thats why some mopar engines "seemed" hotter than others,with basicly the same out put at the flywheel for example,my 85 318 truck came with a low stall tc I went to a tranz shop and got a stock high stall tc for a 225-/6 engine put it behind the 318,(same balance) idles 650 in gear and light throttle it stalls at 1500-1800 rpm and will flash to 2000-2200 rpms when stomped truck is mucho fun to drive now in the mopar catalog they are listed as duel purpose and then there is a race converter this works the same for any combo,a 360 tc will stall higher on a 440 than the stock 440 tc a hemi tc will not stall as high on a 440 it depends on how much torque you put in to one for the amount of stall that you get I am no expert but I have swap a lot of tc and trannys,mix matching to get the results I want with out haveing to use after market high $ tc more to it than you think,IMO
[Re: SPWC]
#456162
09/01/09 04:13 PM
09/01/09 04:13 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
He tells me that any performance Torque converter in the aftermarket(Stall speeds, ect) is actually a Mopar external converter with General Motors internals.
For the most part he has that backwards, if "GM internals" were used the converter wouldn't fit on the Mopar input shaft and reaction shaft. In some cases the converter shell is originally a stock part from another manufacturer with internals modified to fit Mopar shafts; Mopar external hubs, drive lugs and ring gear were installed.
Early examples are the Ford Cortina and the Opel converter which were modified for use on Mopars, GM, etc.
