Re: 904 trans and mopar mini starter's
[Re: Locomotion]
#456149
09/01/09 12:38 PM
09/01/09 12:38 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
I had interference once with an MP mini starter and my former 360. I had to remove the plastic "guard" that goes around the battery lug on the starter. Even then I had to grind a little on the block in this area, to keep the cable end a safe distance from the block. Can it be shimmed to make sure the starter is square to the ring gear? Starter ever been dropped? codfish
[Re: Evil Spirit]
#456151
09/01/09 12:57 PM
09/01/09 12:57 PM
Posts: 4,977 new jersey usa
11secdart
new jersey usa
I always ran 340s with a 904 when I went to a 360 crate short block/ 904 I had to grind a little also to get the mini starter to fit. I think the starters vary a little is size also, I recently switched starters and the one I installed fits even tighter.
