Eddy and Carter carbs running E85? #456000
08/31/09 09:22 PM
08/31/09 09:22 PM
Cab_Burge Offline OP
Are any of you using E85 fuel with Eddy carbs and or the Carter carbs that are plated like the newer Eddy carbs are? If so what jetting and needle and seats are you using? Also what about the acelerator pumps? will the stock ones Eddy uses work or do you need to replace them with a different type? Thanks in adavnce, one of the local Mopar NSS racers needs to know
Re: Eddy and Carter carbs running E85? [Re: Cab_Burge] #456001
08/31/09 09:42 PM
08/31/09 09:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'd be interested in this as well. I have a supercharged 340 with Carters. My new N/SS ride will have Eddy 750s. I was going to go 15-1. But if I could run it on E85 I could back down to 14-1 and be good to go. The price of C-14 could pay for the conversion. I'm not sure a Carter/Eddy has big enough internal passages or bowl capacity to to provide the approx 50% more fuel required.
Doug
Re: Eddy and Carter carbs running E85? [Re: dvw] #456002
09/01/09 02:08 AM
09/01/09 02:08 AM
Anyone, anyone
Re: Eddy and Carter carbs running E85? [Re: Cab_Burge] #456003
09/01/09 05:55 AM
09/01/09 05:55 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I think the acell pump will work fine, if they have a problem try a leather style. I'm quite sure the internals are large enough to support E-85 with some mods. If I had a dyno and some time I'd dial one in n my old test mule. Dave
Re: Eddy and Carter carbs running E85? [Re: quickd100] #456004
09/01/09 06:17 AM
09/01/09 06:17 AM
Sidney Ohio
9SecRoadRunner Offline
Sidney Ohio
make sure you have the metal shaft acelerator pumps and not the plastic ones, alcohol+plastic=problems
You Thinking It's So Doesn't Make It a Fact
Re: Eddy and Carter carbs running E85? [Re: 9SecRoadRunner] #456005
09/01/09 06:27 AM
09/01/09 06:27 AM
mopar heaven
rustbucket Offline
rustbucket  Offline
mopar heaven
I am working on this project now but first I am sending a pair off to be modified with dominator butterflys for more air flow then we will tackle the E85 conversion.
Re: Eddy and Carter carbs running E85? [Re: rustbucket] #456006
09/01/09 08:58 AM
09/01/09 08:58 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
In 2007 Ebrock had a 600 cfm performer , #1414 , that was for use with E85 , but it must not have been popular as I can't find it anywhere but in a 2007 new products flyer .
I'd like to know the answer to this question also as I'd like to use a Thunder 800 with E85
