Replacing 727 seals #455901
08/31/09 07:44 PM
08/31/09 07:44 PM
hemibuzz Offline OP
hemibuzz  Offline OP
How difficult is it to replace the 3 accesible seals, while still in the car????
Re: Replacing 727 seals [Re: hemibuzz] #455902
08/31/09 07:50 PM
08/31/09 07:50 PM
Kirkland, Washington
Pacnorthcuda Offline
Tailshaft is piece of cake. Selector shaft is hard with the valve body still in the tranny (but can be done) and easy with it out.
THe third??? The kickdown? Same as the selector shaft. Couple O-rings you can get too (dip tube and speedo)
