Head porters, 915/906 question #455708
08/31/09 05:05 PM
08/31/09 05:05 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Which ports on the 915/906 heads seem to generally flow more? Which ports usually flow less?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Head porters, 915/906 question [Re: Von] #455709
08/31/09 06:51 PM
08/31/09 06:51 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
It's been a looooong time but, I think the BB 915 and 906 have the same
intake port. Only difference being 915 is closed chamber where 906 is
open.
I believe they will end up flowing about the same as the later model
heads but, with better flow in the .300"-.500" lift range.
The later heads (902,346 and up) are easier to port though.
Re: Head porters, 915/906 question [Re: S/ST 3040] #455710
08/31/09 10:03 PM
08/31/09 10:03 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
open.
I know they are the same intake port, hence the question.
What Im after is which ports generally flow better than the others, 1,2,3,4, etc.
Im asking because I have a set of 915s I need flowed and am comparing them to a set of BS heads that Dwayne did for me. I know what Dwaynes heads flowed on his bench, so Im gonna have both sets flowed to go idea of comparision of flow. My end goal is to see (based on a guess at this point) whether the 915s flow better or the 452s on my motor at the moment flow better. In a few weeks I'll pull the 452s off and flow them also, IF it looks like the 915's will be the winner. I know that Ive read that some ports (1,2,3,or 4) generally flow better than another port on the same casting, just trying to get an idea of what ports to have flowed, or the whole head.
I expect the low lift flows to be mediocore at best on the 452s as the runners have been hogged out, the 915s on the other hand look smoother and are more uniform, fwiw.
Re: Head porters, 915/906 question [Re: Von] #455711
08/31/09 10:37 PM
08/31/09 10:37 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Why not just call Dwayne?
Re: Head porters, 915/906 question [Re: Von] #455712
08/31/09 10:39 PM
08/31/09 10:39 PM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
by the time you spend all that money getting them flowed, you'de be better off getting a set of after-market heads that flow way more than stock heads.
Engine by DeTar http://www.kansasbadman.com
Re: Head porters, 915/906 question [Re: Von] #455713
08/31/09 10:41 PM
08/31/09 10:41 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Well, since you havent got much response yet and i'm curious about this myself, figured i'd chime in. Being that i am no head porter, I've got no earthly idea, but i suspect #4 and 5 exhaust ports flow weird due to the exhaust crossover passage. Intake ports,no idea, but i bet there is 10+ cfm difference best to worse. I wonder if the typical single plane intake would affect the flow of the outer runners more than the inners,considering its angle of approach to the head and the location of the pushrod pinch in the head. Too bad Dwayne Porter isnt on here much anymore. He seems to be the 906 guru.
Re: Head porters, 915/906 question [Re: scatpacktom] #455714
08/31/09 10:43 PM
08/31/09 10:43 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Good point, but Ive already bent his ear plenty, thought Id give him a rest on this one.
Re: Head porters, 915/906 question [Re: CH3NO2] #455715
08/31/09 10:44 PM
08/31/09 10:44 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Id have to flow a sheetload of heads at 20 bucks a head to be in the same $$ range as a set of aftermarket heads.
By the way if you read my post I have a set of ported BS heads. Trying to get this motor in the 10s with stock castings.
Re: Head porters, 915/906 question [Re: Von] #455716
08/31/09 10:51 PM
08/31/09 10:51 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I think the 906/15 will pull away from the pack once properly ported in the .600 and up lift. The key is the short turn radius...
Re: Head porters, 915/906 question [Re: Von] #455717
09/01/09 04:06 AM
09/01/09 04:06 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
How are you going to compare the heads unless you flow both heads on the same bench with the same fixtures? Are you also going to compare port velocity between the heads?
Don't get me wrong, some information is better than none, but I'm not sure how accurate the comparison will be?
Re: Head porters, 915/906 question [Re: 451Mopar] #455718
09/01/09 08:28 AM
09/01/09 08:28 AM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
There is some good info in the tech archive...
http://www.moparts.org/Tech/Archive/bb/62.html
Re: Head porters, 915/906 question [Re: 451Mopar] #455719
09/01/09 08:31 AM
09/01/09 08:31 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Yes, both heads will be flowed. Yes, port velocity will be compared.
Re: Head porters, 915/906 question [Re: CH3NO2] #455720
09/01/09 08:39 AM
09/01/09 08:39 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
What if that is NOT an option ?
Re: Head porters, 915/906 question [Re: JohnRR] #455721
09/01/09 08:46 AM
09/01/09 08:46 AM
What happened to being "happy if it'll go 11.50's"???
Instead of posting silly questions on here, all you gotta do is plunk down 3K to have Dwayne pimp out your iron heads and you'll be there.........
