Re: A body fenderwell headers
[Re: BILLYJAY]
#455581
08/31/09 03:00 PM
08/31/09 03:00 PM
Posts: 2,361 PA
70HemiGTX
PA
here are mine. Hookers. I thought I had better pictures, but I don't.
[Re: 70HemiGTX]
#455582
08/31/09 03:40 PM
08/31/09 03:40 PM
Posts: 388 wine valley
cudaben1968
wine valley
so where would i go to get a template for the cutting of the fender wells? and where the heck is ur brake booster?
Half measures availed us nothing. We stood at the turning point.
-Alcoholics Anonymous, The Big Book
[Re: PolyDart]
#455587
09/01/09 12:19 AM
09/01/09 12:19 AM
cudaben1968
wine valley
im looking at a set of old pro parts 2" and im thinking i will most def. get them. but here is a question
68 b cuda, motor plate (stock location engine) 440 with victors. will i run into more clearance problems since the headers will be .250 in higher?? (raised ex. ports)
[Re: cudaben1968]
#455591
09/01/09 02:53 PM
09/01/09 02:53 PM
Posts: 5,444 So Cal
Sinitro
So Cal
Problem with the Proparts is their different length of tubes, some are as long as 48" and others are as short as 34". Yes... They fit but will take the HP down by 50...
Just my $0.015..
[Re: Sinitro]
#455592
09/01/09 08:57 PM
09/01/09 08:57 PM
Posts: 567 Sth.IL
dare_dude
Sth.IL
This is the first time i heard this???????? About losing HP!
Post deleted by moparts
[Re: dare_dude]
#455593
09/01/09 09:07 PM
09/01/09 09:07 PM
#455594
09/01/09 10:10 PM
09/01/09 10:10 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
There MIGHT be 10-15 Hp difference between the Hookers and the Pro Parts,but not 50.
We have the Pro Parts on our car and they work very well.
[Re: Chris2581]
#455595
09/05/09 02:55 PM
09/05/09 02:55 PM
Posts: 5,444 So Cal
Sinitro
So Cal
We had custom headers built and the dyno difference was almost 50HP between the ProParts and custom.. The install is in a 71 Duster, built 440, Tunnel ram, runs high nines.. As mentioned previously check out the major tube length differences of the ProParts.... Just my $0.015..
[Re: Sinitro]
#455596
09/05/09 03:14 PM
09/05/09 03:14 PM
Posts: 247 nc
moeflo
nc
Just my $0.015..
Same collector design and dimensions? Do the flanges mate up to the ports the same? What I'm asking is, are the only difference between the two sets primary length?
[Re: moeflo]
#455597
09/09/09 11:50 PM
09/09/09 11:50 PM
Posts: 5,444 So Cal
Sinitro
So Cal
Just my $0.015..
Not complicated.. Flanges, ports, diameter and collector are virtually the same.. Basic difference was that all tubes were of equal length(50"). As mentioned previously check out the mismatched length of the Pro-Parts tubes, now go check out the Hookers or others..
On a full race built 440 the mismatched header tube lengths will cost alot of hp..
Just my $0.015...
