A body fenderwell headers #455578
08/31/09 02:09 PM
08/31/09 02:09 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Could someone post some photos of fenderwell headers in a A body
Re: A body fenderwell headers [Re: flatiron] #455579
08/31/09 02:54 PM
08/31/09 02:54 PM
Lake Charles,Louisiana
BILLYJAY Offline
BILLYJAY  Offline
Here's my early A-Body..63 Dart..Custom built 2 1/4" headers
Re: A body fenderwell headers [Re: BILLYJAY] #455580
08/31/09 02:54 PM
08/31/09 02:54 PM
BILLYJAY Offline
BILLYJAY  Offline
here's another one withou the alum..
Re: A body fenderwell headers [Re: BILLYJAY] #455581
08/31/09 03:00 PM
08/31/09 03:00 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
here are mine. Hookers. I thought I had better pictures, but I don't.
Re: A body fenderwell headers [Re: 70HemiGTX] #455582
08/31/09 03:40 PM
08/31/09 03:40 PM
wine valley
cudaben1968 Offline
cudaben1968  Offline
wine valley
so where would i go to get a template for the cutting of the fender wells? and where the heck is ur brake booster?
Half measures availed us nothing. We stood at the turning point. -Alcoholics Anonymous, The Big Book
Re: A body fenderwell headers [Re: cudaben1968] #455583
08/31/09 04:05 PM
08/31/09 04:05 PM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
Abody low deck w/Stage VI heads
Re: A body fenderwell headers [Re: 1974 474 Duster] #455584
08/31/09 05:35 PM
08/31/09 05:35 PM
BILLYJAY Offline
BILLYJAY  Offline
there is no template...it is trial and error.. the tubes need to be a specific lenght as well as routed properly.. this is why i had a chassis builder or someone who is familar with the math as well as the construction of headers.. it's not just putting some tubes together..what you build at home if done wrong could hurt your motor's performance greatly...lots of guys build them, but if you are not aware of what you need to be doing then you are going to do what i mentioned above..waste lots of time and lots of money buying header kits..they can be 300-500 per kit and if you make more than just a few mistakes then you are going to start buying induvial pcs or another complete kit trying to build something you have no concept of.. they is a science to tube lenght as well as collector size and then trying to get them all to fall out together with the correct lenght... GOOD LUCK !!!!!!!!!!!!
Re: A body fenderwell headers [Re: BILLYJAY] #455585
08/31/09 08:30 PM
08/31/09 08:30 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Hooker 2" Supercomps
Re: A body fenderwell headers [Re: PolyDart] #455586
08/31/09 08:30 PM
08/31/09 08:30 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Re: A body fenderwell headers [Re: PolyDart] #455587
09/01/09 12:19 AM
09/01/09 12:19 AM
wine valley
cudaben1968 Offline
cudaben1968  Offline
wine valley
im looking at a set of old pro parts 2" and im thinking i will most def. get them. but here is a question
68 b cuda, motor plate (stock location engine) 440 with victors. will i run into more clearance problems since the headers will be .250 in higher?? (raised ex. ports)
Re: A body fenderwell headers [Re: cudaben1968] #455588
09/01/09 01:15 AM
09/01/09 01:15 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I run the pro-parts on a Duster with a 400 low deck with the -1 heads. I didn't have any problems, save for the rear drivers side tube, but that because I'm running a mid-plate. Other than that they fit like a glove...
Re: A body fenderwell headers [Re: 70dusterjohn] #455589
09/01/09 02:45 AM
09/01/09 02:45 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
after many years they tend to crack on the center 2 tubes ...but its worth it--just re-weld them.
i LOVE fenderwells - makes a LOT of stuff WAY easier to work on compared to regular headers !
Re: A body fenderwell headers [Re: 493_DART] #455590
09/01/09 03:23 AM
09/01/09 03:23 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
couldn't find fenderwells that fitted so i made my own.
Re: A body fenderwell headers [Re: cudaben1968] #455591
09/01/09 02:53 PM
09/01/09 02:53 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Problem with the Proparts is their different length of tubes, some are as long as 48" and others are as short as 34".
Yes...
They fit but will take the HP down by 50...
Just my $0.015..
Re: A body fenderwell headers [Re: Sinitro] #455592
09/01/09 08:57 PM
09/01/09 08:57 PM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
This is the first time i heard this???????? About losing HP!
Post deleted by moparts [Re: dare_dude] #455593
09/01/09 09:07 PM
09/01/09 09:07 PM
Re: A body fenderwell headers #455594
09/01/09 10:10 PM
09/01/09 10:10 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
There MIGHT be 10-15 Hp difference between the Hookers and the Pro Parts,but not 50.
We have the Pro Parts on our car and they work very well.
Nautilus Racing-
Re: A body fenderwell headers [Re: Chris2581] #455595
09/05/09 02:55 PM
09/05/09 02:55 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
We had custom headers built and the dyno difference was almost 50HP between the ProParts and custom..
The install is in a 71 Duster, built 440, Tunnel ram, runs high nines..
As mentioned previously check out the major tube length differences of the ProParts....
Just my $0.015..
Re: A body fenderwell headers [Re: Sinitro] #455596
09/05/09 03:14 PM
09/05/09 03:14 PM
nc
moeflo Offline
moeflo  Offline
nc
Just my $0.015..
Same collector design and dimensions? Do the flanges mate up to the ports the same?
What I'm asking is, are the only difference between the two sets primary length?
Re: A body fenderwell headers [Re: moeflo] #455597
09/09/09 11:50 PM
09/09/09 11:50 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Just my $0.015..
Not complicated..
Flanges, ports, diameter and collector are virtually the same.. Basic difference was that all tubes were of equal length(50").
As mentioned previously check out the mismatched length of the Pro-Parts tubes, now go check out the Hookers or others..
On a full race built 440 the mismatched header tube lengths will cost alot of hp..
Just my $0.015...
