To verify TDC,remove valve cover and watch #1 cylinder rockers.When the intake valve closes,continue to rotate engine while watching the rotor in the distributor and timing mark,Stop at TDC on timing mark.The rotor should be pointing at #1 on the cap.That is a good staring point.Put every thing back together,verify spark and fuel squirt.Crank it up,farts out the pipes
![](/ubbthreads/images/graemlins/sawzall-smiley.gif)
,too retarded, Fire out the carb
![](/ubbthreads/images/graemlins/weld.gif)
,too advanced.Keep a large clean rag handy in case of fire in the carb
![](/ubbthreads/images/graemlins/fan.gif)
.Sometimes it's too hard to just blow it out. 2 rags if ya got dual carbs.
![](/ubbthreads/images/graemlins/hammer.gif)
