anyone use a true trac in a 8 3/4 ? #455231
08/31/09 01:16 AM
08/31/09 01:16 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
went out to a T&T on Friday night to try a few things/practice prior to the Nationals.
first pass,launched and thought i had axle tramp - no such luck .
drove home,pulled the centre not much left of the spider gears.crown and pinion were ok
dana is not an option where i live,cost,but i can get a true trac.anyone used one thoughts ? to be used in a street/strip car.3710lbs,mid/low 11's
thanks
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: anyone use a true trac in a 8 3/4 ? [Re: tex013] #455232
08/31/09 01:23 AM
08/31/09 01:23 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
*snickers* crown ...
Was it a clutch or a cone type?
Re: anyone use a true trac in a 8 3/4 ? [Re: CokeBottleKid] #455233
08/31/09 01:58 AM
08/31/09 01:58 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
clutch type
Tex
New best MPH 130.32
Re: anyone use a true trac in a 8 3/4 ? [Re: tex013] #455234
08/31/09 07:51 AM
08/31/09 07:51 AM
NY usa
540challenger Offline
NY usa
i run a truc trac in my car.
71 Challenger 727 408 small block,
i have had it in the car for 3 years right now with no problems.
My tires i am running are mickey thomas et street radials 275/50/15 with SuperStock springs. Plenty of hard lunches on them.
however this is a street car and never been to the track. Also if you are running stock style axle bearing you will need to order a trust spacer as the unit doesn't come with it.
If you have "green bearing" then you don't need the spacer, also you don't need the limited slip additive.
