Re: 65 dodge header question
[Re: prochargedhemi]
#454889
08/30/09 08:47 PM
08/30/09 08:47 PM
Stock heads they fit fine, raised port heads they rub the steering shaft and lay against the starter causing problems. You must add 1" to the tube under the header and dimple #1 to clear steeing shaft.
[Re: 65dodgebob]
#454892
08/30/09 10:15 PM
08/30/09 10:15 PM
I run motor plates pass side is tight but fits, stock mounts may create a problem.
