Worse than I thought....... #454833
08/30/09 07:05 PM
08/30/09 07:05 PM
Deerfield, Ohio
70dusterjohn Offline OP
Deerfield, Ohio
Sooo I drag the old dart out, and strat working on it.. Getting it ready for next year, maybe.. So I start taking the paint off in the fender well/engine bay the frist thing I notice is that some one welded in a patch over the whole top of the inner fender. So not a big deal I was going to take them out and replace with alum. Sooooo after I start doing that, I notice that the firewall is rusted in the wheel wells also.. Man this is getting bad.. I mean I got the car and knew it needed a lot of work, but the frame was good. the guy that had it tried to cover it up with what looks like seam sealer. So now I'm losing focus on it. I don't know what to do. The floor pans are bad also .. I know that by making it a drag car, I'm saving it. I have been buying sheet metal for it for awhile. and now have a lot, but I still need all the window trim, and lots of parts. Just thinking that I should cut my loses and move on. Or just keep pluging away on it. I got like 5 grills for it 4 doors and 4 fenders, and 2 hoods.. complete interior with buckets. Thinking bout selling that stuff to buy much need parts.. I just don't know what to do with it.. Sorry for the rant...
Re: Worse than I thought....... [Re: 70dusterjohn] #454834
08/30/09 07:10 PM
08/30/09 07:10 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Got any pics John?
Re: Worse than I thought....... [Re: ProSport] #454835
08/30/09 07:22 PM
08/30/09 07:22 PM
Deerfield, Ohio
Deerfield, Ohio
I'll take some and post it.. Its bad.. I mean I'm sure I can fix it, but its gona be fun...
Re: Worse than I thought....... [Re: 70dusterjohn] #454836
08/30/09 07:42 PM
08/30/09 07:42 PM
Deerfield, Ohio
Deerfield, Ohio
There's a hole on the other side to, also you just can't see how bad or big it really is.. Its the whole well..
Re: Worse than I thought....... [Re: 70dusterjohn] #454837
08/30/09 07:49 PM
08/30/09 07:49 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i dont know john. its hard to build them from that point and stay ahead of the game. if its gonna be a drag car maybe, but if its gonna be a total restore i dont think i would. been there done that and now i have 35,000 invested in a car thats worth maybe 20,000 tops.
Re: Worse than I thought....... [Re: mopar dave] #454838
08/30/09 08:44 PM
08/30/09 08:44 PM
Deerfield, Ohio
Deerfield, Ohio
It's going to be a drag car, but I want it to look right too.. If I patch it, no one will see it.. but I will Know it's there..
Re: Worse than I thought....... [Re: 70dusterjohn] #454839
08/30/09 08:58 PM
08/30/09 08:58 PM
my own world
theraif Offline
theraif  Offline
my own world
Well try to look on the plus side all ready have holes to run bars down to tie the whole cage/car together
Re: Worse than I thought....... [Re: theraif] #454840
08/30/09 09:20 PM
08/30/09 09:20 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Or you could just cage it and then cut all the rot out and build a custom firewall. Move it back and put in a removable trans tunnel and you'll have all kinds of room to work.
Re: Worse than I thought....... [Re: WILD BILL] #454841
08/30/09 09:24 PM
08/30/09 09:24 PM
Deerfield, Ohio
Deerfield, Ohio
Yep, Bill thats kinda what I was thinking.. I mean heck I got just what I asked for, something I could cut up and not feel bad about it, and now I'm like why did I go that route... I'm not sure what to do with it, but I got so ideas.. Keep it coming guys..
Re: Worse than I thought....... [Re: WILD BILL] #454842
08/30/09 09:25 PM
08/30/09 09:25 PM
Hemiroid Offline
Hemiroid  Offline
It doesn't look that bad to me? I've owned, built and worked on much worse. Floorboards are easy to replace and it looks like a little sheetmetal repair on the firewall and you'll be good to go.
Re: Worse than I thought....... [Re: Hemiroid] #454843
08/30/09 10:03 PM
08/30/09 10:03 PM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
I'm going through the same thing myself. Now we are building a tube chassis car out of it. Good Luck,
Curtis
Taking over the World one win light at a time.
Re: Worse than I thought....... [Re: 70dusterjohn] #454844
08/30/09 10:10 PM
08/30/09 10:10 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
I was at the same point with my 68 Dart about 1.5 years ago, it was actually worse than that. I ended up making 2 cars into 1 as the 68 had good rails/rockers and I had a 67 with a good firewall/inner fenders and rear clip but the rails/rockers/floors were shot from sitting in the dirt.
After a month or so of planning I started bracing up the body and getting it square then started cutting and swapping, I had to haul it to a frame machine before I could hang the rear clip because the only thing holding the rear rails was what was left of the trunk gutter and the rails were pushed up about 3", the decklid was serving as part of the rear suspension since everything else was gone.
It was about the same deal up front, I swapped the firewall and inner fenders from the donor, and installed new pans front & rear, while I was at it I also seam welded all the factory spotwelds top & bottom, It's time consuming but I only had about $600 in parts for 4 new pans and the donor car.
At least if you go thru the whole car you will know there isn't and hidden rust or damage.
Re: Worse than I thought....... [Re: Hemiroid] #454845
08/30/09 10:30 PM
08/30/09 10:30 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
totally...like you mentioned it will be a RACE CAR, not a concours restoration...don't sweat it man!
Plymouth Makes It!
Re: Worse than I thought....... [Re: RoadRunnerLuva] #454846
08/30/09 11:37 PM
08/30/09 11:37 PM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
I know someone that is in need of a fender if you decide you have an extra.
Re: Worse than I thought....... [Re: TheBlackCar] #454847
08/31/09 10:54 AM
08/31/09 10:54 AM
Deerfield, Ohio
Deerfield, Ohio
Most of the fenders that I got would need a lot of work.. I think I only have one good fender for each side.. Which one is he looking for..
Re: Worse than I thought....... [Re: 70dusterjohn] #454848
08/31/09 11:03 AM
08/31/09 11:03 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have two darts out back a 67 and 68.one is complete and one shell both can be had very,very cheap.
