Re: rons alcohol users
[Re: Dodgeman67]
#454376
08/30/09 12:06 PM
08/30/09 12:06 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
After the first prime at the track, we never needed to time it again. It always started. The trick to warming up the engine is pulling the barrel valve near closed, enough for a fast idle, then let it set with out water pump or fan on....cycle the water pump on for a few seconds every minute to avoid hot spots in the cylinder heads. We Hardly ever used the fan at all.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#454377
08/30/09 12:26 PM
08/30/09 12:26 PM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
I use a Ron's Primer Plus and after many years of using one of their Flying Toilets all I can say is I sure would have used a lot less alcohol over the years...best investment I ever made, starts are easier, water temp is easier to control, oil is less milky, etc, etc, etc...
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: MegaDart]
#454380
08/30/09 01:37 PM
08/30/09 01:37 PM
Posts: 1,522 Wisconsin
Garceau
Wisconsin
First you need to be talking to James Monroe before purchasing the system, get it from him. He is Rons biggest dealer and one of the best bracket racers in the country go to his site www.killerrons.com and check it out. the primer plus is Monroe's deal. The primer is Rons deal. There is a huge difference. With the plus you can drive on pump gas all through the pits, warm it up on gas, and drive the return road on gasoline. You switch it to Alky at the burn out box and shut the alky down at the return road and come back on gasoline. Saves a TON of alky, and makes warm ups a breeze. You dont get to drive at much more than 2500rpms or so, but thats all you need. Our entire family runs Rons systems through Monroe. Great guy.
[Re: 70VcodeCoronetRT]
#454381
08/30/09 02:01 PM
08/30/09 02:01 PM
RapidusMaximus
Weatherford, Texas
Rapid can you tell me a little more about the primer plus? I'm guessing you have to start cranking and hit the primer plus switch to fire the motor to avoid flooding? Does it feed enough gas to move the car to the stagging lanes? Is the only control for the primer plus the knob? Sorry for the newbie ?s but I have never seen one in person. Thanks
I turn the switch on for a split second to get some gas flowing then hit the starter, fires right up. The system has an adjustment knob on it and you just twist it until you obtain the desired RPM. I have been able to drive to and from the staging lanes on gas, then switch to alcohol as I pull into the water box, make a pass then swith it back to gas as I'm coming down the return road. And yes, if you forget and leave the pump on it WILL flood the engine. Really a simple deal, and as everyone else has said James Monroe is a first class deal.
[Re: Garceau]
#454383
08/30/09 02:17 PM
08/30/09 02:17 PM
Posts: 1,151 Las Vegas
afxcoronet
Las Vegas
Like my brother said, I use the primer plus and love it. I actually run mine off of the old fuel cell in the trunk and an old Holley Blue pump. I run the primer plus up to the water box, and actually switch back to gas in the shut down area. I use very little alky, less than .5 gallon a pass, and have no trouble making heat. Good luck with it, let me know if you have any other questions. I love it fill up the fuel cell in the trunk on the way to the track and I'm set. Curtis
Taking over the World one win light at a time.
[Re: afxcoronet]
#454384
08/30/09 04:10 PM
08/30/09 04:10 PM
Posts: 5,406 Diego-Town, CA
Diego_Ted
Diego-Town, CA
After talking to Curtis, we got the primer system! Car starts right up and warms up no problem. I use the system to the waterbox and as soon as I pass the stripe. sure saves a ton on Alky!! The only problem HOLLYWOOD worries about is fouling the plugs because there is some soot left but I think we may be a little rich?? One thing is wiring ours is not wired to the ignition so you have to make sure you shut the system down other wise you get a motor full of GAS don't ask me how I know!! LOL
Diego
