Thanks Robert....
With your help & suggestion I may have solved the problem. The problem with the gauges occurred in both the park and headlights on position. I remembered that I left the connector loose on the back of the dimmer/dome light switch because I've been taking the connector off to test and attempt to solve a problem with my dome light not working when operating the thumb wheel switch on the dash. I left it somewhat loose so I could get it off easily to do some testing. I did like you said and pushed it on all the way and it appears that that solved the problem even though I don't see a connection between the dash light dimmer/dome light switch and the gauges. But again, a big MOPAR thanks to ya!
