LA roller 318 #453860
08/29/09 09:46 PM
08/29/09 09:46 PM
Fortworth TX
mod5v Offline OP
mod5v  Offline OP
Fortworth TX
Got a free "89" 318 to build for my truck. I have not tore into one of these roller motor yet and was wondering if the cam has provisions for a fuel pump eccentric? I did pop a v-cover and it has the 302 heads and the timming cover has a fuel pump blockoff plate on it. Just looking at building a millage motor as cheap as possible. Have a t-quad intake and a e-brock 1406 carb and headers for it will go in a 84 D150 short bed. 904 lockup and 2.94 rear with 28 to 29" tall tires.
Re: LA roller 318 [Re: mod5v] #453861
08/31/09 07:39 AM
08/31/09 07:39 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
maybe. if it came out of a car (5th ave, diplomat), yes, if it cam out of a truck (TBI) not sure. if it doesn't you can buy a camshaft snout extender from hughes for $18 to be able to run a fuel pump eccentric.
if you want some power out of it, too, get the puny little cam reground. I had bullet cams regrind mine with their 259/316HR lobe on both the intake and exhaust--I'm using mag heads, and the exhaust flows a lot better than the 302 heads. regrind is like $150, shipping both ways is ~$30. the roller lifters can be reused. the pushrods, probably, too. if you're serious about mileage, I'd maybe drop the intake lobe down to the HR247/306 lobe and the exhaust to the HRL256A lobe. hughes 1110 springs should work good for these lobes.
2017 Grand Cherokee Overland
Re: LA roller 318 [Re: patrick] #453862
08/31/09 08:34 AM
08/31/09 08:34 AM
scratchnfotraction Offline
it will have the short nose cam
get the adaptor from HUGHES and run a mech fuil pump..easy fix
any after market cam will work with the stock roller lifters,and they should be the oil there roller so you can up to mag heads later
I just opened mine up and cleaned then reused
rull the lunati VooDoo 60710 in mine with comp 901-16 springs and all stock hardware
