Pushrod question?
#453726
08/29/09 08:30 PM
08/29/09 08:30 PM
Posts: 761 KY
juicedcuda
KY
Do you think manton or smith bros can make a 5/16 pushrod that would be equally as strong as a 3/8? I am running a pretty stout solid roller.
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
Re: Pushrod question?
[Re: juicedcuda]
#453727
08/29/09 08:39 PM
08/29/09 08:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm pretty sure they can but the wall thickness would make them pretty heavy.... its alot easier to pick up the strength in the diameter
[Re: MR_P_BODY]
#453728
08/29/09 08:46 PM
08/29/09 08:46 PM
Posts: 761 KY
juicedcuda
KY
Yeah but I have already clearanced the heads as much as I am comfortable with and I am still afraid that a 3/8 would lay on the head and not sit in the rocker cup all the way.
1970 Plymouth 'Cuda
1973 Gold Duster
[Re: juicedcuda]
#453729
08/29/09 08:56 PM
08/29/09 08:56 PM
MR_P_BODY
If you dont have any 3/8 push rods that are the right length to test with.... get a piece of 3/8" threaded rod and cut it to length and hit the ends on a grinder so they sit in the cup and lifter and check it... its a cheap way to check... just use a light test spring
[Re: MR_P_BODY]
#453730
08/29/09 09:17 PM
08/29/09 09:17 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
If you do find you need to run 5/16 pushrods, Smith Brothers makes 'em.
I'm running 8.35" X .115 wall in a solid roller application (540# pressure over the nose of the cam) in a B engine.
They've been first-class guys to deal with.
I'm running offset rockers (too good a price to pass up) on Stealth heads, hence the small pushrod.
BTW, I'd run 3/8" if there were room...
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: juicedcuda]
#453731
08/30/09 11:41 AM
08/30/09 11:41 AM
Posts: 4,209 New York
polyspheric
New York
In practical terms, it's impossible. Almost all of the column stiffness of a pushrod is a function of its diameter (not wall thickness), and even a solid 5/16" bar is weaker than a 3/8" OD pushrod with only 1/32" wall. Compared to a common 3/8" .083" wall, it's 53% as stiff.
Boffin Emeritus
[Re: juicedcuda]
#453732
08/30/09 12:03 PM
08/30/09 12:03 PM
how "stout" are the springs for that roller and what is the approximate length?
[Re: juicedcuda]
#453734
08/30/09 01:45 PM
08/30/09 01:45 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
Well, your open pressure is about a hundred pounds over the pushrods are about an inch longsr. Don't know if what I'm getting away with will work for your setup or not. But, the guys who make the parts can tell you: pushrods.net or (800) 367-1533 If anybody'd know, I'd bet they would. -Bill
[Re: polyspheric]
#453735
08/30/09 04:29 PM
08/30/09 04:29 PM
Posts: 2,128 sweden
sshemi
sweden
And a 5/16 solid is weaker than a 5/16 tube.
[Re: sshemi]
#453736
08/30/09 06:31 PM
08/30/09 06:31 PM
polyspheric
New York
Widely repeated, but wrong. Removing metal does not increase stiffness, it increases stiffness per pound, or stiffness per square inch of load.
Boffin Emeritus
[Re: juicedcuda]
#453737
08/30/09 11:08 PM
08/30/09 11:08 PM
The approximate length is 9 5/8" long. The springs are Comp, here are the specs:
Dual Valve Springs I.D. of Outer Dia.: 1.125" # I.D. of Inner Dia.: .719" # Seat load: 228lbs @2.050'' # Open load: 636lbs @1.300'' # Coil bind: 1.192'' # Rate: 544lbs/in # With damper.
you should be able to get 5/16 pushrods that will handle that with no problem.
