Ring question #453628
08/29/09 07:50 PM
08/29/09 07:50 PM
Can , Nova Scotia , Cape Breto...
caper Offline OP
caper  Offline OP
I just reringed my engine. I had Total Seal rings in it , I noticed the chrome moly peeled of in spots. What caused this to happen?
Also on the side of the piston nearest the spark plug , the piston land just above the top ring is very rough for about 4 in . What caused that?
Re: Ring question [Re: caper] #453629
08/29/09 08:03 PM
08/29/09 08:03 PM
UK
602heavy Offline
602heavy  Offline
UK
Too much heat and/or detonation causes the moly to get blown off , had this problem when i sprayed over a 150 shot of nitrous.
Re: Ring question [Re: 602heavy] #453630
08/29/09 08:32 PM
08/29/09 08:32 PM
Detonation, to lean, makes the Moly and the piston tops melt
