thrust block 8.75? #453613
08/29/09 06:37 PM
08/29/09 06:37 PM
CT USA
N
Nick Mineau Offline OP
N
CT USA
hi
do all sure grip rears use the same lenght thrust block. and if so do u have to dissimable the rear to install it. where can u buy one? thanks
nick
Re: thrust block 8.75? [Re: Nick Mineau] #453614
08/29/09 07:06 PM
08/29/09 07:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
All 8 3/4" Sure-Grips use a 1 1/2" wide thrust block, the thrust buttons in the clutch type can be removed without splitting the case but the cone type has to be disassembled to remove the thrust block.
